bad svt problems!!!HELPPP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-15-2013, 10:31 PM   #1
02svtf1326
Fan#: 76507
What I Drive: 2002 silver svtf zx3
FF Reputation: 1 02svtf1326 Good Standing Member
Exclamation bad svt problems!!!HELPPP
Ok just today I went to start my 2002 SVT Focus and it took quite a bit of turning over to finally start but it finally did. I let it run for awhile (prob around 5-10 mins) I then noticed that the header was getting really hot as in glowing orange hot. The coolant hoses around the header were smoking a little bit! I then shut the car off till I had to move it out of my driveway (it was still hard to start). Any suggestions as to what is wrong would be much appreciated! Thanks
Hatch Nation #31
02svtf1326 is offline
Old 01-16-2013, 09:21 AM   #2
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,811, Level 100
Points: 51,811, Level: 100 Points: 51,811, Level: 100 Points: 51,811, Level: 100
Level Up 0% Completed
Forum Activity 32%
Activity: 32% Activity: 32% Activity: 32%
Buy-Sell-Trade Rating: (28)
I would need more info
How did it run when you had it running
Have you checked the water level
are the fans coming on when the engine gets hot
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is offline
Old 01-16-2013, 09:24 AM   #3
Dads03SVT
Dads03SVT's Avatar
Fan#: 58979
What I Drive: 2003 Red SVT
FF Reputation: 1 Dads03SVT Good Standing Member
Last time i seen a post of this nature the cat was clogged...
Dads03SVT is offline
Old 01-16-2013, 12:10 PM   #4
02svtf1326
Fan#: 76507
It ran fine and started up easy until the alternator went. I just replaced it and got everything back together and it was hard to start.. it has to turn over for about 5 seconds. I heard something about the vct solenoid going bad and causing this?
Hatch Nation #31
Old 01-16-2013, 12:11 PM   #5
02svtf1326
Fan#: 76507
Its never gotten hot. Well the fluids at least. But the header gets glowing freaking hot just at idle
Hatch Nation #31
Old 01-17-2013, 10:05 AM   #6
paulj6567
Fan#: 39752
What I Drive: 2003 infra red Focus SVT
FF Reputation: 1 paulj6567 Good Standing Member
Sounds like a clogged cat
It's not what you drive but how you drive it!
paulj6567 is offline
Old 01-17-2013, 11:10 AM   #7
1turbofocus
FF Affiliate
Fan#: 1123
Forum Activity 32%
A 100% clogged CAT would still let the engine start normal , it just wouldnt have any power taking off and would run poorly
Customer Support
AIM: hpdyno
Phone: 704-249-3745
Elder 1turbofocus
Old 01-17-2013, 03:17 PM   #8
02svtf1326
Fan#: 76507
So I'm going to put my money on the vct solenoid!! Thanks guys!!
Hatch Nation #31
Old 01-21-2013, 07:11 PM   #9
02svtf1326
Fan#: 76507
Exclamation
Ok guys.... changed out the vct solenoid...went to start it up and the same thing happened..it turns over for a good 10 seconds then starts almost like its carburated ...and the header still got hot rly fast and glowed again... I'm lost on what it could be! If the block was cracked would it do this? What else would cause this?
Hatch Nation #31
Old 01-21-2013, 09:09 PM   #10
tukaniSVT
FF PHOTOG ENTHUSIAST
tukaniSVT's Avatar
Fan#: 5521
What I Drive: 2003 SVT Focus 2009 BMW 335i
Points 36,504, Level 100
Points: 36,504, Level: 100 Points: 36,504, Level: 100 Points: 36,504, Level: 100
FF Reputation: 34 tukaniSVT Great Standing Member
did you check the Cat?? I read you checked the VCT Solenoid, but the people here are suggesting you check your Cat.
Maybe, you should check that. Take it a muffler shop if you want them to check it.
Or if you have an OBDII Reader, unplug your cat and run your car for a couple of minutes. IT WILL BE LOUD ... but if the headers don't turn red, and all you get is the 2nd O2 sensor issue, then it's your cat.
And the code for the O2 sensor would be because you would be doing this test with out the cat in.
Ray
Hatch Nation Member: #147
R.I.P - FELLOW FF MEMBER, IZZY, BLK2k3GTS, will always be remembered. We will compete on a different course again one day.
tukaniSVT is offline
