trunk wont close. suspect related to key - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-14-2013, 07:16 PM   #1
dbeethe
Fan#: 108528
What I Drive: 2003 Ford Focus zx
FF Reputation: 1 dbeethe Good Standing Member
Just bought a 03 focus. Discovered the trunk will not latch closed. Tried to turn the key and it doesn't work at all. put the key in, but it refuses to turn. I suspect that is the problem. Could i be right?
dbeethe is offline
Old 01-14-2013, 07:40 PM   #2
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,770, Level 78
Points: 14,770, Level: 78 Points: 14,770, Level: 78 Points: 14,770, Level: 78
Level Up 80% Completed
Forum Activity 17%
Activity: 17% Activity: 17% Activity: 17%
FF Reputation: 16 Elizabeth Great Standing Member
The latch inside the trunck lock may be already 'out' or in the locked position. So it is hitting the "U" shaped latch. Check in the trunk at the lock and try to push the locking part/pin back while turning the key.
It may have gotten damaged by slamming the trunk down.. and is why the key is jammed...
Elizabeth is online now
Old 01-14-2013, 08:08 PM   #3
dbeethe
Fan#: 108528
the problem is I can't turn the key at all. I put it in and it won't budge..
dbeethe is offline
Old 01-14-2013, 09:26 PM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
Since you just bought the car, you don't know the history.
I wouldn't be surprised if the hatch is not keyed to the same key as the rest of the car.
The latch is motorized, if you push the hatch unlock button on the dash, does it make a motor "buzzerp" sound? If it does not, then I would go with the assumption that the latch motor may need to be replaced, check craigslist for a focus being parted out, around here you can buy a complete hatch for $50.
elsolo is offline
Old 01-15-2013, 12:55 AM   #5
amc49
Fan#: 96610
Points 3,376, Level 36
Points: 3,376, Level: 36 Points: 3,376, Level: 36 Points: 3,376, Level: 36
Level Up 18% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Or latch assembly could just be jammed from pissed off people trying to force it shut instead of thinking it out.....................sometimes a simple screwdriver stuck in the right place can render it useable again, of course original problem will have to be fixed, often just the side bumpers or latch getting out of adjustment.
amc49 is online now
