Damaged coil packs! - Focus Fanatics
Old 01-14-2013, 11:22 AM   #1
Gotch26
Fan#: 108513
What I Drive: 2007, silver, zetec climate.
FF Reputation: 1 Gotch26 Good Standing Member
Damaged coil packs!
Hi, this is my first post and I'm looking for some advice.
I live in the UK and own 2007 ford focus. In the last 6 months it has developed a reoccurring fault with the coil pack. I have replaced it 3 times and still have a problem.
Can anyone tell me if this a common thing and if so, how can it be resolved.
Thanks in advance
Gotch26
P.s some mentioned to me the wiring between ecu and coil pack!
Gotch26 is offline
Old 01-18-2013, 06:55 AM   #2
Classic6200
Fan#: 108694
What I Drive: 2000 Silver SE
FF Reputation: 1 Classic6200 Good Standing Member
coil
Hi. I recently changed out my coil pack to the ACCEL brand as it was less expensive and I also had isssues with a stumble.
Came to find out that the plug that connects to the coil pack had one side tab broken and this allowed vibrations to cause the misfire.
I used 2 zip ties to cinch the plug to the coil pack and problem solved
Classic6200 is offline
Old 01-18-2013, 10:32 AM   #3
nilskje
Fan#: 11478
What I Drive: Focus -04 5door 1,6 Ghia
FF Reputation: 17 nilskje Great Standing Member
Replace the plugs and the wires & the coilpack at the same time, use the Ford HT cables and make sure you get the upgraded coilpack unless you already have this also, chk the connector that goes to the coilpack with the 3 wires the a prone to breaking. Guess a new coilpack lasts only for a little while?
nilskje is offline
Focus Fanatics Ford Focus Forum offers many fun ways for you to engage with other Ford Focus Owners from across the world. Whether it be about the aftermarket performance modifications, technical how-to's, European tuned suspension or awesome fuel economy similar to the Acura TLX. You can find all Ford Focus related information here. Join our Ford Focus discussion forums and chat with local Focus enthusiasts in your area.
