sporadic's Turbo Duratec build #2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 06-04-2012, 10:02 AM   #1
sporadic
sporadic's Avatar
Fan#: 12724
Points 12,861, Level 74
Points: 12,861, Level: 74 Points: 12,861, Level: 74 Points: 12,861, Level: 74
Level Up 3% Completed
Buy-Sell-Trade Rating: (12)
Talking sporadic's Turbo Duratec build #2
Original build from 7/24/2007 is here: sporadic's Turbo Duratec build thread
This second build is going to stretch into 2013 and will be broken down into phases. Since I will be the one tuning it this will greatly simplify the adjustments I have to make.
Phases
1) Swap out the IHI/16T hybrid turbo for a GT2871r (Target: June 2012)
This will involve welding in a wastegate flange for an external wastegate, the dump tube, and a few inches of new downpipe. The turbine outlet is a 2.5" v-band flange, which will immediately open to a 3" downpipe. Tune for the 8psi wastegate spring. No boost adjustment yet.
2) Cossie knock-off intake manifold. (Target: July/August 2012)
This involves moving the power steering reservoir and re-routing some lines. I may do a detailed write-up of this if I have time. Adjust tune. May add boost controller and go to 10psi if logs look OK.
3) Built motor (2013)
There are still many variables here to account for. The only part I have in hand at the moment is a set of 88mm 10.1:1 Supertech pistons. These were used in a 2.3 build for a few thousand miles, and started life closer to 10.6:1 and were professionally milled to a lower compression.
The current plan is to use the stock 2.0 head and cams, but that could change.
My original goal was ~400whp, but instead of jumping ahead I think I'm going to shoot for ~300whp and leave some room for future fuel system upgrades for a phase 4. Basically I'll push it until I nearly max out the stock fuel system.
I considered lower compression pistons, but I decided I'd rather run the slightly higher compression to start with and if I want to go lower I'll use a thicker had gasket. If I started with lower compression and wanted to go higher it will cost much more to mill the head vs. buying a thicker head gasket.
This build will not be real-time like my first one (I have 2 kids now), but I will provide photos and write-ups once phases are complete.
NOTE: This is not now nor will ever be a dyno queen. I will post dyno results if I happen to go with a group for a dyno day. Please don't skip around this thread and expect to find a dyno sheet. This isn't that kind of build. I'm far more likely to provide datalog information and 1/4 mile track times than dyno charts.
Parts list (on shelf)
GT2871R turbo (T3, 63ar, 2.5" v-band out)
Tial 38mm wastegate & dump tube piping
T3 Log manifold from build #1
55lb injectors
Parts list (Still to purchase. PM me if you have and want to sell.)
2.0 Connecting rods (leaning towards K1)
Rod bearings
Head gasket (can't decide between Fel-Pro or Cometic and also thickness)
Bottom end gasket kit
Top end gasket kit
Torsen LSD
Clutch (Exedy Hyper Single or maybe even the Clutchmasters FX700)
MAFia for 2005+ Ford (had one, went to 3" MAF so I sold it. Now I think I'll need one again)
60lb injectors
Drag wheels + slicks
Boost controller (might go with electronic)
Larger intercooler
Parts credit (I'll had to this for any person/company who cuts me a deal on parts)
- Top Speed for 38mm Tial wastegate ($150 lightly used was a good deal)
- Tantalus for pistons
- koke'sfocus for intake manifold
- afraziaaaa for ARP fasteners and gasket kit
Pictures
I'm more of a Coke Zero guy, but for some reason there are Pepsi cans around when I take pictures.
I figure this might help some people if they are considering the GT2871r.
If my calculations are correct my Phase 1 at 8psi will be peak at the intersection of 1.7 Pr and 27.7 lbs/min at 7K RPM. I can't wait to run it at 20+psi/2.7Pr and let it ride that island to 45lbs/min! I'm fairly certain that will require a return-style fuel system.
These are just estimates. I'd have to do some data logging to map out real-world results. I might do just that. Mapping the lb/min and RPM from the datalog on the compressor map should be very helpful. I did that with the IHI but didn't post it.
-3AN .035 oil restrictor
Compressor outlet adapter. These are surprisingly expensive at $40 from ATP Turbo.
sporadic is online now
Old 06-04-2012, 04:20 PM   #2
Jgrove998
i <3 my ST
Jgrove998's Avatar
Fan#: 45311
Buy-Sell-Trade Rating: (13)
Can't wait to see the progress!
2012 Fusion SE 3.0L V6
'86 XR4Ti ; 2.3L Turbo, 15psi
1988 F150 Custom
D23 Crew: #07
Jgrove998 is offline
Old 06-04-2012, 05:00 PM   #3
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Buy-Sell-Trade Rating: (11)
progress man !
FF MODERATOR
RIFF CREW
ZXthrizzle05 is online now
Old 06-04-2012, 06:29 PM   #4
SaleenT121
SaleenT121's Avatar
Fan#: 57997
What I Drive: 05 Saleen Focus
Points 3,153, Level 34
Points: 3,153, Level: 34 Points: 3,153, Level: 34 Points: 3,153, Level: 34
Level Up 69% Completed
FF Reputation: 3 SaleenT121 Good Standing Member
That's one cute bolt-on you got there lol!
Saleen Focus #74
-Carbon Hood and trunk
-SVT rear Disc brake conversion
-Custom fab turbo kit
-Built 2.0L by Turbo Turtle
SaleenT121 is offline
Old 06-04-2012, 09:05 PM   #5
sporadic
sporadic's Avatar
Fan#: 12724
Lol. Thanks man! My daughter saw me taking the photo and I asked her if she wanted her picture taken too. She emphatically said yes!
Old 06-06-2012, 04:30 PM   #6
Gettysburg150
Gettysburg150's Avatar
Fan#: 97408
What I Drive: 08 Silverfrost Metallic SE, 5 speed
Points 1,255, Level 19
Points: 1,255, Level: 19 Points: 1,255, Level: 19 Points: 1,255, Level: 19
Level Up 55% Completed
FF Reputation: 2 Gettysburg150 Good Standing Member
Just read your other build post, cant wait to see this one! Rep given
Sedan Revolution Two Three Zero
FRPP, "Stealth" CAI, Debadged, wider tires, louder stereo, turbo mainfold in the wrong place...
Gettysburg150 is offline
Old 06-06-2012, 04:34 PM   #7
sporadic
sporadic's Avatar
Fan#: 12724
Thanks!
I think I just need one more fitting for the water lines and I'm good to go. I might start the turbo swap early next week.
It's been so long since I did any proper data logging and tuning that I need to validate my previous stuff before moving forward.
For my own personal reference I think I'll include more tuning related information in this thread.
Old 06-06-2012, 04:55 PM   #8
Gettysburg150
Fan#: 97408
I would love to see some tuning info, I'm a bit of a data junkie
Old 06-19-2012, 11:04 PM   #9
sporadic
sporadic's Avatar
Fan#: 12724
I started installing the GT2871r today. The fit isn't as perfect as I thought, but it does fit. The turbine housing angle is a bit different than the IHI I built the manifold for and the result is a rather large gap between the block and the turbo. The new turbo is positioned up about 1" and out 1", putting the compressor housing almost against the coolant lines.
I did break one of the plastic coolant T's on removal so I'll be hitting Napa for another one. (PN 660-1593)
I'm still debating whether to dump the wastegate or pipe it back into the exhaust. I'll probably run it dumped at first.
I also broke off one of the nipples on the evaporator for probably the 4th time. I'm getting tired of gluing it back on.
Completed:
- Remove old turbo
- Mock up new turbo and determine necessary modifications to piping
To do:
- Modify downpipe for 3" V-band
- Modify hot site pipe (eliminates a 90* bend)
- Modify ambient pipe
- Route coolant lines
- Mock up wastegate
- Weld in wastegate and route dump
- Datalog and tune
The gap. It's unnecessary but hey I'm not going to hack up my manifold if I don't have to.
IHI RHB52/16T hybrid vs. GT2871r
The new beast:
And one more for fun:
Old 06-23-2012, 10:23 PM   #10
sporadic
sporadic's Avatar
Fan#: 12724
Downpipe is complete and I also replaced the horrible compression style clamps with 3" v-band clamps. Next up is the wastegate, which I decided to route back into the exhaust. I'm going to mount the wastegate on the underside of the manifold (since there is room), that way all pipes will be nice and short.
Old downpipe for the Tbird IHI compared to the new downpipe for the GT2871r:
v-band!
Old leaky junk vs. v-band
