Rattle noise, Im almost stumped - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus SVT > Focus SVT
Focus SVT The place to chat about general questions, window tinting, exterior body, interior and lighting upgrades for the MK1 2002-2004 Focus SVT.
Old 03-18-2013, 07:23 PM   #11
ddrepin
Fan#: 109933
What I Drive: 2002 Pitch Black ZX3 SVT
FF Reputation: 1 ddrepin Good Standing Member
I had a rattle and it was because the valve cover wasn't all the way tightened so that could be a place to look into. Also the heat shield around the exhaust under the car could be loose and rattling which was another problem of mine.
ddrepin is offline
Old 03-18-2013, 08:29 PM   #12
nvmaddog
Fan#: 68677
What I Drive: 2002 Red SVT
FF Reputation: 1 nvmaddog Good Standing Member
That cat bracket and the heat shield are a lot of the times the cause of a rattle. Even if it is simply cracked it will still rattle.
2002 Red 3 Door SVTF #2458
nvmaddog is offline
Old 03-19-2013, 07:04 AM   #13
hockeydoc33
hockeydoc33's Avatar
Fan#: 90937
What I Drive: 2003 Screaming Yellow SVT
FF Reputation: 1 hockeydoc33 Good Standing Member
Got it fixed thanks.
It was the sway bar end links.
hockeydoc33 is offline
Old 03-19-2013, 02:14 PM   #14
Spyrojoe
Fan#: 111549
What I Drive: 2002 SVT Focus CD Silver
FF Reputation: 1 Spyrojoe Good Standing Member
I was about to mention that. When I picked up my '02 it had some crazy rattling problems. I researched it and a lot of people seemed to have good luck after replacing the end links. I figured it was worth a shot since it was a cheap fix and would probably need to be done at some point anyway. Swapped them out and all my rattle woes were gone.
Spyrojoe is offline
Old 04-02-2013, 02:13 AM   #15
KeepinitRIL
KeepinitRIL's Avatar
Fan#: 85498
What I Drive: Red 90 Fauxbra & Black SVTf
Points 637, Level 12
Points: 637, Level: 12 Points: 637, Level: 12 Points: 637, Level: 12
Level Up 74% Completed
FF Reputation: 1 KeepinitRIL Good Standing Member
The heat shield on the cat did make a rattle noise at 2100RPM, but I took the cat off. Yay RT Cat
I replaced the trans and passenger side mounts. I still have the rattle :/
Im going to put the stock dogbone back in and see if that does it.
Bought 9/2/2008 - Red 90 GT Mustang - Sold 7/26/2011
(291hp 378tq)
Bought 5/28/2011 - Black SVT Focus - My DD
(hp and tq, not enough)
KeepinitRIL is offline
Old 04-21-2013, 11:02 PM   #16
JKane
JKane's Avatar
Fan#: 104351
What I Drive: SVT S/C
Points 1,361, Level 20
Points: 1,361, Level: 20 Points: 1,361, Level: 20 Points: 1,361, Level: 20
Level Up 61% Completed
Level up: 61% Level up: 61% Level up: 61%
FF Reputation: 1 JKane Good Standing Member
Buy-Sell-Trade Rating: (19)
Lower Trans mount is always a suspect, can't hurt to upgrade it!
JKane is offline
Old 04-22-2013, 12:45 AM   #17
KeepinitRIL
Fan#: 85498
Problem Solved!
While doing an oil change Friday, I was laying down and bumped a bolt on the cross member and it made the same rattle noise. So I poked around and found it
So I am STOKED no more annoying god-awful rattle noise
(291hp 378tq)
Old 04-22-2013, 02:11 AM   #18
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,696, Level 23
Points: 1,696, Level: 23 Points: 1,696, Level: 23 Points: 1,696, Level: 23
Level Up 96% Completed
FF Reputation: 1 Bogey Good Standing Member
Which bolt?
Bogey is offline
Old 04-22-2013, 02:25 AM   #19
KeepinitRIL
Fan#: 85498
I believe it was this guy in the picture
Im pretty sure it was this guy. The top nut was a B!#^H to get to
PS: not my car
(291hp 378tq)
Old 04-22-2013, 01:28 PM   #20
XxSVT VENOMxX
Fan#: 113779
What I Drive: 2003 silver frost SVT focus
FF Reputation: 1 XxSVT VENOMxX Good Standing Member
Rattle noise
Same problem. It's either coming from the shield by the transmission or it sounds like its coming from under the motor.
XxSVT VENOMxX is offline
