2012 suitable power wire for Sony XDP-MU110 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-13-2013, 01:14 PM   #1
Johnny Rotten
Fan#: 100824
What I Drive: 2012 Ford Focus SE Gray
FF Reputation: 1 Johnny Rotten Good Standing Member
I recently purchased the Sony XDP-MU110 from Crutchfield . This unit has a small 4 channel amp and digital signal processor . Would just like to improve sound quality with the non Sony 6 speaker system . I have veiwed many posts here as to the location of speaker wire tap in locations (passenger side console wiring harness) but would like to power the unit from another source other than the battery . Their are a red (acc) and a yellow (battery) wire that need to be connected . From what I've read the red wire should be ok with the power antennae harness wire . The slightly larger gauge yellow wire is my question . Where can I locate power for this connection ? The amp is only rated at 17 watts x4 rms 45x4 max and would be mounted under the passenger seat . Simply put I do not want to run through the fire wall to battery for such a small unit. Does anyone have suggestions or know of an adequate tap in source near this wiring harness ? Enjoy all the detailed info here it really helps .Thanx.
Johnny Rotten is offline
Old 01-13-2013, 10:25 PM   #2
mrpeaches
Fan#: 103895
What I Drive: 2012 White Focus SE Hatchback
FF Reputation: 1 mrpeaches Good Standing Member
I would be concerned about doing that from a safety perspective. Even though it's only pulling 15 amps at max (((45Wx4)/12V)=15A) that's still a fair amount of extra load to put on the factory wiring in addition to whatever load would already be present on whatever line you were considering splicing into.
If you're dead set on not doing the safe thing and running a new, fused power line from the battery through the firewall, then pretty much your only option would be to look in the passenger foot well for the fuse box and tap into a fuse rated for higher than 15A. I can't remember if there are any there or not. If you go this route, use an add-a-fuse and don't just wrap the wire around a prong and shove it in.
mrpeaches is offline
