Am i missing something??? Double din - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-13-2013, 12:42 PM   #1
Urbanspacedude91
Urbanspacedude91's Avatar
Fan#: 91432
What I Drive: 2010 Blue Flame Duratec
Points 2,302, Level 29
Points: 2,302, Level: 29 Points: 2,302, Level: 29 Points: 2,302, Level: 29
Level Up 2% Completed
Forum Activity 5%
FF Reputation: 1 Urbanspacedude91 Good Standing Member
Question Am i missing something??? Double din
So basically im hooking up a pionner double din and i bought the harness and dash kit so it should be plug and play. My concern is that the kit i bought came with one set of wires and i see on other kits its two sets of wires. Would i need the other set???
Heres the links so theres and idea of what im talking about.
http://www.ebay.com/itm/Ford-Radio-S...0a2060&vxp=mtr
http://www.ebay.com/itm/FORD-Focus-2...ccb338&vxp=mtr
Do i need the second set of wires??? Or did i just do something wroing as easy as this could be??
I drive a Focus and You noticed!
Urbanspacedude91 is offline
Old 01-13-2013, 01:10 PM   #2
badazz2010focus
Fan#: 78166
What I Drive: 2010 ingot silver 2 dr 5 speed
Points 19,276, Level 87
Points: 19,276, Level: 87 Points: 19,276, Level: 87 Points: 19,276, Level: 87
Level Up 86% Completed
Forum Activity 12%
FF Reputation: 7 badazz2010focus Good Standing Member
Yeah one might be a sync harness if you dont have sync then you dont have to worry about it
badazz2010focus is online now
Old 01-13-2013, 05:24 PM   #3
Urbanspacedude91
Fan#: 91432
Forum Activity 5%
I do have the sync so without the harness the radio wont turn on at all??
Old 01-14-2013, 03:09 PM   #4
Urbanspacedude91
Fan#: 91432
Forum Activity 5%
bump
Old 01-14-2013, 07:25 PM   #5
badazz2010focus
Fan#: 78166
Forum Activity 12%
you'll loose sync capibilty I dont have sync myself so I dont really know what would happen if you tried to use a base harness on a sync system as to wether or not the headunit would turn on or not...I mean I dont see why it wouldnt because all the sync harness does is retain it.
Old 01-15-2013, 09:21 AM   #6
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
the first link with the second plug with the rca's on it is for if you have the factory sub so that you can retain it. the second one doesn't have the sub connector included. neither of those will retain sync (that's a special harness with a module on it.
here's the issue you will have with either of those kits. there is no accesory power in the factory harness on the 08-11 focus. with either of those you will need to run an acc wire to somewhere else in the car such as the ignition harness. there are harnesses made that will take the factory data signal and give you an acc output and another harness that will allow you to retain sync as long as the aftermarket headunit has an aux input on it (preferably on the back).
here's the one to retain sync
http://metraonline.com/part/AFSI-02
i can't find the other one at the moment, they may not make it anymore.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 01-16-2013, 05:22 PM   #7
Urbanspacedude91
Fan#: 91432
Forum Activity 5%
YOU ARE THE MAN!!!
Old 01-16-2013, 05:29 PM   #8
Urbanspacedude91
Fan#: 91432
Forum Activity 5%
So i shouldnt have to worry about adding another ground or 12v constant?? Just an acc wire?? Thisis the info i been looking for that took me like three days to find. Can i just run it to the ign switch fuse??
Old 01-17-2013, 09:41 AM   #9
Kipp
Kipp's Avatar
Fan#: 31300
constant and ground are in the factory radio harness so that's not an issue. just need to get acc from somewhere else. i'm not a fan of doing fuse taps, but alot of people use them with no issues. you just need a good acc source (does not have power during start) and tap that and make sure to put an inline fuse on it for added protection and you should be good.
Midwest Crew #22
Kipp is offline
Old 01-17-2013, 09:55 AM   #10
Urbanspacedude91
Fan#: 91432
Forum Activity 5%
You have no idea how valuable your info is . Thanks alot im doing this tonight!!
