Power Steering Fluid is Foaming - Focus Fanatics
Old 01-13-2013, 09:40 AM   #1
clayton89
Fan#: 108214
What I Drive: 2006 Sonic Blue ZXW
FF Reputation: 1 clayton89 Good Standing Member
I just purchased a 2006 ZXW with the 2.0L Duratec last week. Yesterday while driving I swore I heard a noise that sounded like I was low on power steering fluid and sure enough as I turn the last corner to come home the power steering is really tough and is growling/whining. So i pop the hood to check the fluid level and the power steering fluid is foaming out of the cap. Any ideas as to what could be the issue?
clayton89 is online now
Old 01-13-2013, 09:54 AM   #2
05focusST91
05focusST91's Avatar
Fan#: 83640
What I Drive: 2008 chevy cobalt SS/TC.
FF Reputation: 6 05focusST91 Good Standing Member
Probably have air in the system, is the fluid clean? Try taking the cap off and turn the wheel from wheel stop to stop with the car running to push some of the air out, also check for leaks from anywhere in the rack/p.s lines
Funtion>form.
FLOOR IT!
2005 focus ST (gone)
Still here!
05focusST91 is offline
Old 01-13-2013, 10:37 AM   #3
jdetzel
Fan#: 102548
What I Drive: 2012 White Titanium Hatchback
FF Reputation: 1 jdetzel Good Standing Member
Do this, but first let it rest awhile to let the foam subside. Maybe even take a turkey baster and suck out as much foam as you can. Then fill the reservoir with clean fluid.
Otherwise you may just pump the foam back through the system.
jdetzel is offline
Old 01-13-2013, 03:22 PM   #4
A7xschecter6661
A7xschecter6661's Avatar
Fan#: 98263
What I Drive: 2011 Focus SEL
FF Reputation: 2 A7xschecter6661 Good Standing Member
If your fluid is low or dirty do the above recommended with the turkey baster. This is the lazy way to change fluid, I did it on my girlfriends saturn.
I sucked as much as I could out, topped it off with clean fluid had her turn back and forth (front of vehicle jacked up, engine running), repeated until fluid was 90% clear which took about 2 quarts. I would assume you would have it mostly clean after a gallon
You'll never get it all unless you do an actual flush though.
A7xschecter6661 is offline
Old 01-13-2013, 03:26 PM   #5
05focusST91
Fan#: 83640
Yeah even flushes only get about 80-85% out, we use the jb machine/additive+fluid at my job and it works great, a professional flush would be the best way to go
Funtion>form.
FLOOR IT!
Still here!
Old 01-13-2013, 04:06 PM   #6
clayton89
Fan#: 108214
Ok so here if my findings. This initially happened last night so it was bone cold when I did this test today. I pulled the car off the street and the pump whined for a little bit "i'm assuming since it was still foaming and making noise when i got home" then became quiet this took roughly 30 seconds from start to park. I let it sit in the drive for few hours then jacked it up and put on stands.
I did as 05FocusST91 said and tried to burp/bleed the system with the car off. My GF cycled back roughly 30 times, and I noticed some bubbles at first where there was some air but then the fluid just moved around like normal from turning the wheel.
Took the car off the stands and went for a 10 minute drive, pump was quiet the whole time even through my crazy parking lot maneuvers to try to promote the foaming issue. So I thought all was good until my foot got heavy after a corner. Almost as soon as I let off I could hear the pump whining and the next corner it was most certainly whining. I did not stop but continued to take the 5 minute trip across town to go home the pump whining most of the way, about halfway I don't hear it anymore.
When I get home I pop the hood and see where what looks like a little spilled from foaming up, but there was no foam at all in the reservoir.
Last night right before I heard the whining I was full throttle off the light shortly before my house. Anyone have any Ideas as why a full throttle run could cause the power steering fluid to foam?
Oh and should I have tried to burp/bleed the system with the car running or not?
Old 01-13-2013, 04:40 PM   #7
Elizabeth
Elizabeth's Avatar
Fan#: 89280
What I Drive: '12 Yellow Focus SE stick, 17"rims
FF Reputation: 14 Elizabeth Great Standing Member
The fluid line connection to the power steering pump is flexing at higher throttle and allowing bits of air into the system. Or the power steering pump has a crack in it.
Just a guess but fits the symptoms.
Maybe all you need is to check the connections and tighten them?
Elizabeth is online now
Old 01-13-2013, 05:50 PM   #8
clayton89
Fan#: 108214
Hmm.. That seems like a good start, I'll have to check and do some research
Old 01-15-2013, 10:06 AM   #9
Miller88
Fan#: 73790
What I Drive: 2011 Focus SE 5 Speed
FF Reputation: 5 Miller88 Good Standing Member
Do you live in a rust state? More than likely one of the lines rusted out a bit and is letting the air in.
2011 Focus SE 5 Speed 36k - Blue Flame Metallic - Added Rear Swaybar
2000 Jeep Cherokee Sport 115k - Lifted with mud tires.
Miller88 is offline
Old 01-15-2013, 10:20 PM   #10
clayton89
Fan#: 108214
Unfortunately yes I do live in a rust state, but it is going into the local garage to have it looked at. Hopefully something is just loose, I just dont have the space to do it myself.
