Suspension Upgrade - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus Third Generation > MK3 Focus
Old 01-12-2013, 08:11 PM   #1
Bliky
Bliky's Avatar
Fan#: 95135
What I Drive: 2012 Sterling Gray Focus Titanium
FF Reputation: 4 Bliky Good Standing Member
Suspension Upgrade
So, for a long time I've been thinking about a suspension upgrade and I already have the Steeda Rear Sway Bar so my next step would be either springs (steeda probably) or coil-overs. Doing research for coilovers I discovered there's ST ones, KW ones (3 versions), KSport and H&R ones.
I had originally decided I'd go with KSport since they are on amazon and I have gift cards and such but I also realized the KW ones are on amazon as well. Honestly I'm not sure which I should go with now. I basically want the best performance I can get from them.
Those who have installed coilovers, what do you guys recommend?
Also, should I consider springs instead? What are the benefits of either?
Lastly, if I were to go with coilovers (or I guess springs) how should my alignment setup be? I mean things like toe and camber for a good street performance setup.
'12 Sterling Grey Titanium Hatch - Moonroof / Winter Package / DCT / 17' Alloy Wheels
MK3 Manual Transmission Swap: http://bit.ly/1ondtuV
Bliky is offline
Old 01-14-2013, 12:21 AM   #2
Bliky
Bliky's Avatar
Fan#: 95135
Anyone? I'm honestly not sure what to do.
Bliky is offline
Old 01-15-2013, 07:52 AM   #3
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
What I Drive: 2014 SGM Fusion Ti
FF Reputation: 37 jdubhack Great Standing Member
Buy-Sell-Trade Rating: (12)
I would, if I were you, run springs for a drop and not coilovers. I say this only because I see you're located in NJ and the winters there get rough. Coilovers will rust and salt gets in the thread pretty easily.
<>< Gal. 6:14
April 2013 HOTM
2013 Ford Fun Weekend: Show Class Winner
jdubhack is offline
Old 01-15-2013, 08:52 AM   #4
Zillon
Zillon's Avatar
Fan#: 17393
What I Drive: '13 GTI
FF Reputation: 27 Zillon Great Standing Member
Whatever springs you do go with, choose ones that are linear and not progressive. They'll handle better, handle more consistently, ride better, and if you're pairing with your stock dampers, your dampers will last longer.
The Steeda springs are good springs. I'd strongly recommend pairing them with the OEM ST front dampers and Koni yellow rear shocks.
Joined the dark side.
Zillon is offline
Old 01-15-2013, 09:04 AM   #5
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
This man is what one might call a "guru." Heed his advice and you will do well.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 01-15-2013, 10:05 AM   #6
2012sel
2012sel's Avatar
Fan#: 84814
What I Drive: 2012 Red Candy SEL 5 door
FF Reputation: 10 2012sel Great Standing Member
So would you recommend the Steeda (are they not progressive?)...
http://www.steedafocus.com/parts/ste...g-springs.html
Over the Eibach Pro-Kits? (description says they are progressive)...
http://www.steedafocus.com/parts/201...g-springs.html
By the way Zillon, thanks for sticking around and staying involved. The setup on you're ex-Focus is what I'm going for. What Kind of RSB did you have and did you like it?
Current
2012 SEL 5 door w/Premium Package - April 2011 | 1957 Chevrolet 3200 - 2005
Past Rides
2000 F150 Sport 2000-2011 | 1988 Ranger XLT 4wd 1988 - 2000 | 1966 Mustang 1983 - 2008 | 1963 Ford Econoline Van 1979 - 1983
2012sel is offline
Old 01-15-2013, 10:07 AM   #7
jdubhack
I WILL correct you.
jdubhack's Avatar
Fan#: 103056
He had the Steeda RSB...which is now on my car.
<>< Gal. 6:14
April 2013 HOTM
jdubhack is offline
Old 01-15-2013, 11:44 AM   #8
Zillon
Zillon's Avatar
Fan#: 17393
I had the Pro-kits on my car, and they didn't match well with the stock dampers. They were a little bouncy/floaty at the limit. Had the Steeda springs been available when I got the Pro-kits, I would've chosen the Steedas.
Give Steeda a call, I'm sure they'll be able to answer any questions you might have. I'm fairly certain that they are, in fact, linear-rate springs.
Progressive = variable spring rate, depending on spring compression
Linear = consistent spring rate throughout the suspension travel
Progressive springs often ride rougher and bounce more, which will drastically shorten the life of most dampers. Also, at the limit, they often can exhibit unpredictable handling characteristics (snap oversteer), since the spring rate exponentially increases with travel. The increased spring rate can induce an unexpected loss of traction.
Zillon is offline
Old 01-15-2013, 11:57 AM   #9
2012sel
2012sel's Avatar
Fan#: 84814
Thanks. I spent some more time searching and found a post by SteedaBrandon that answers the question. The Steedas are progressive.
Originally Posted by SteedaBrandon View Post
Not sure if you are referring to the one that I posted. If so, then yes. I can assure you that that car at the time I took the picture had our springs installed. I can show you a before picture if you'd like?
They are progressive.
Here's the original post...
http://www.focusfanatics.com/forum/s...9&postcount=85
Current
Past Rides
2012sel is offline
Old 01-15-2013, 12:15 PM   #10
Zillon
Zillon's Avatar
Fan#: 17393
Well, that's a disappointment. Good catch, though.
Zillon is offline
