Old 01-11-2013, 10:02 PM   #1
gondorian
Fan#: 105695
What I Drive: 2002 Ford Focus SE Wagon 5spd Zetec
FF Reputation: 7 gondorian Good Standing Member
How-To: $5 shifter base fix (00-02.5)
So yesterday I began replacing my shifter cables and broke my shifter base.
I'm pretty sure it was already cracked, but I didn't feel like buying another plastic one or spending $150 for a short throw shifter, so I decided to fix my broken one. Here is what I did:
Bought a 4" 11/16 electrical panel cover and some bolts at home depot
Cut off the little knobs under the shifter base.
Cut the panel to size.
Drilled holes in the base and then put the bolts through the metal plate and the shifter.
Then I added an extra support bracket made from the cut out materiel in the spot where the base started to fail and where I think it gets the most stress.(hard shifts from first to second)
After everything fit nicely dry I took it apart and added liberal amounts of JB weld.
Now I just need to let it dry overnight and then put it back it the car. We'll see how it holds up but I think it will do pretty well.
gondorian is online now
Fan#: 1
Old 01-11-2013, 10:20 PM   #2
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 2002 Land Yacht (Windstar)
FF Reputation: 263 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
I'll edit your title and we'll add this to the How-To when you're finished. Good job!
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 01-11-2013, 10:30 PM   #3
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
What I Drive: 2002 ZX3
FF Reputation: 18 freemind Great Standing Member
Buy-Sell-Trade Rating: (16)
That's smart
133whp-126ftlbsTQ Eclipse CD8443,JBL Px300.4, JBL GTO7001, PPI 356cs, JBL p1022 in .95 cubes, RAAmat BXT, Damplifier Pro
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 01-11-2013, 10:46 PM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
FF Reputation: 42 sleepyboy Great Standing Member
Buy-Sell-Trade Rating: (10)
Pretty cool, people can doe this if they see it cracking before it gets too bad.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-12-2013, 07:48 AM   #5
freemind
freemind's Avatar
Fan#: 67513
That's even smarter!
Hatch Nation #140
freemind is offline
Old 01-12-2013, 09:18 AM   #6
markwb
markwb's Avatar
Fan#: 105077
What I Drive: Ford Focus ZXW 2006
FF Reputation: 1 markwb Good Standing Member
Very ingenius fix on the shifter base, and very cost affective too. Nice work.
Mark
2003 Pontiac Bonneville SSEi
IBEW Local 261
"My Other Vehicle is a Nuclear Submarine"
markwb is offline
Old 01-12-2013, 12:35 PM   #7
2007wagon
Fan#: 107858
What I Drive: 2007 wagon
FF Reputation: 1 2007wagon Good Standing Member
Very good idea. I will have to keep this in mind when I change my cable.
2007wagon is offline
Old 01-12-2013, 01:06 PM   #8
whynotthinkwhynot
Captain TMI
Fan#: 18416
Actually neither of you have this style of shifter. This shifter base is on vehicles 2002.5 and older. 02.5+ MT vehicles use a different Tri-ax setup where the shift cable connects to the shifter arm above the pivot point, and the gate cable is operated by a rod is perpendicular to the shift arm at the pivot point. I don't think it is as susceptible to cracking as the old design. If you are planning on changing cables I just recently wrote about adjusting cables according to Helms instructions, and the Ford Special tool needed- which might be in your glove box. If you have a red C shaped plastic thing that has been in your glove box for a long time and you can't figure out what it is- it is for adjusting the shift cables.
Be eclectic.
Old 01-12-2013, 08:31 PM   #9
2007wagon
Fan#: 107858
Well...it was still a nice write up. Thanks for the heads up and I will your write up...thanks again.
Old 01-13-2013, 10:57 AM   #10
gondorian
Fan#: 105695
Here it is installed. It seems to be working pretty well. I've been driving around without my center console so I can look at it. I can definitely see that the extra bracket is taking some of the stress when I'm shifting and I'm glad I put it on.
P.S. If you are taking pictures of your car's internals with a DSLR use a lens hood, mine saved my lens a bunch of times when I was shooting during this project.
