Share SYNC Status Checker Tool Results
I'm looking curiously at the results file that is saved on one's USB stick after running the "SYNC Status Checker Tool" from SyncMyRide.com and I think there is lots to learn from this.
The problem is I only have a copy from my Focus with it's version numbers etc.
So if anyone wants to help me out by uploading a copy of the that the program leaves on your USB stick (after you use it in your car but before you upload the results to syncmyride.com) it would be a huge help to me.
The file is found in the folder "SyncMyRide" and would be called something like Sync_4K8W01QM_1XXXX11X11X111111 (or Sync_4K8W01QM_1XXXX11X11X111111.xml), with the last part being your VIN number.
It might be smart to remove your VIN number from it first.
You could post it here or PM it to me.
Either way, it'd be a huge help thanks!!
