H&R Front sway bar too much? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-09-2013, 09:26 PM   #1
PSUrivie
PSUrivie's Avatar
Fan#: 67329
What I Drive: Boostin in the Mid-A
Points 7,191, Level 56
Points: 7,191, Level: 56 Points: 7,191, Level: 56 Points: 7,191, Level: 56
Level Up 21% Completed
FF Reputation: 15 PSUrivie Great Standing Member
Buy-Sell-Trade Rating: (10)
So right now I have a FRPP rear sway bar (25mm) and a Saleen front sway bar (which I believe is 22mm).
The H&R front sway bar is 24mm. Do you guys think that is too much bar for the front? I have GAZ shocks (damping adjustability) and Focus RS springs. My car sees mostly street driving.
Ideas?
FSWerks stg2 w/ water/meth; Cossie intake.
PSUrivie is offline
Old 01-10-2013, 08:13 AM   #2
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 13,819, Level 76
Points: 13,819, Level: 76 Points: 13,819, Level: 76 Points: 13,819, Level: 76
Level Up 43% Completed
Forum Activity 100%
Activity: 100% Activity: 100% Activity: 100%
That H&R bar is adjustable at the end= has 2 hole postions to put the end link thru. The end w/ the most roll stiffness is going to see more weight tranfer. You already have a 22mm fsb. If there something your looking for? I also have a 22mm eibach fsb. It works great for me.
felixthecat is online now
Old 01-10-2013, 11:08 AM   #3
SVTFOCI03
SVTFOCI03's Avatar
Fan#: 103052
What I Drive: 2003 Silver Svt Focus
FF Reputation: 1 SVTFOCI03 Good Standing Member
Are you looking to make the car handle better by adding a bigger sway bar?
SVTFOCI03 is offline
Old 01-10-2013, 11:59 AM   #4
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
I don't think there will be enough difference to justify replacing the Saleen/Eibach bar you have already.
elsolo is offline
Old 01-10-2013, 01:10 PM   #5
PSUrivie
PSUrivie's Avatar
Fan#: 67329
yeah, I thinking it'll give me a little more handling. However, I'm not sure if it will hinder the handling characteristics than improve them.
PSUrivie is offline
Old 01-10-2013, 02:22 PM   #6
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,906, Level 59
Points: 7,906, Level: 59 Points: 7,906, Level: 59 Points: 7,906, Level: 59
Level Up 78% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Well how neutral is your handling now? Are you looking for more neutral, under/oversteer? If you have too much oversteer, then a larger front bar can help but might cause too much understeer if its too big tricky
Unless some one chimes in and says they have gone through both setups (along with the gaz/rs spring combo) that you are talking about and it was much improved, I'd say to pass on it. If it was as easy of an install as a rear sway bar, there would be no discussion needed as you would easily just swap one out and compare. Front sway bar is a pita to do, so if you dont like the results, you'd have to go through that process again. Unless you have access to a garage/lift, air tools and can get the work done easily.
It may be worth it if it does make an improvement but for me, I'd have a hard time justifying it for normal street use. If you start racing and need to fine tune your handling, then it might be something to try out.
rambleon84 is offline
Old 01-10-2013, 02:37 PM   #7
Buickboy
br/o/stang
Buickboy's Avatar
Fan#: 28542
What I Drive: 72 Skylark, '12 Mustang
Points 28,322, Level 98
Points: 28,322, Level: 98 Points: 28,322, Level: 98 Points: 28,322, Level: 98
Level Up 98% Completed
FF Reputation: 39 Buickboy Great Standing Member
Buy-Sell-Trade Rating: (29)
22/25 is a really nice combo but as others have side it comes down to personal taste. Ive also read that too big of a bar up front can lead to not being able to put the power down coming out of a corner
==2012 Kona Blue Mustang V6==
==1995 Light Iris Neon Coupe==
==1972 Skylark==
Buickboy is online now
