DURATEC Performance (2003-2011) The place to chat about any Duratec 23, 23E, and 20 engine performance, tuning and exhaust related upgrades.
#1 | ||||
FF God of South FL
Dogbone install issues need help ASAP
Hey i am midway install in the dark getting eaten by mosquitoes is FL and im installing a CFM ply dogbone mount and i have run into 2 issues 1) it looks like my tranny doesn't align with the body mount. 2)The CFM mount wont go into the tranny mount like if the poly urethane bushing is to large it gets 85% in and then gets stuck i dunno if i should grease it up and try and shove it in there.
Also i have a 2007 manual i am 100% i ordered the correct mount just checked my order with CFM
02 Black ZX5 R.I.P. 07 Black ZX3 Work in progress Last of the Hatches #1 XBOX LIVE:TKE428 GIVE REP POINTS IF IM HELPFUL |
| Sponsored Links | |||
Advertisement | |||
#2 | ||||
I drive this!
Pry bar, wood block and hammar will be your friends with this install.
"When does the zetec kick in" Asked by a Honda enthusiast |
#3 | ||||
I did a poly bushing swap by myself at night. when I needed that extra push I started the car up and rocked the engine. Probably not recommended but I had work in the morning. Good luck.
#4 | ||||
I drive this!
You don't need to start it up? Can also use a jack under the trans to help manipulate the position.
#5 | ||||
So mote be it
that's what I had to do. needed lots of help getting it lined back up. pita but worth it. just have to use force, be good to have some one else helping, wasn't easy with the car only on jack stands getting leverage
#6 | ||||
FF's Night Security
Yup, I used a jack to help align it as well, though other times I didn't. Have you ever replaced your passenger side? I know mine was worn out and was letting the motor sit a lot lower than it should have.
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#7 | ||||
yea jack it up and manhandle it into place. Best part about these engines is when you take off the motor mounts everything shifts position.
#8 | ||||
Where am I?
Moved to "Duratec Performance".
Moderator for: Great Lakes Fanatics, Zetec Performance Chat, Wheels, Tires, Brakes & Suspension,Ford Focus & General Car Chat, Buy-Sell-Trade, General Forced Induction & Ecoboost and General Chat Lounge |
#9 | ||||
FF God of South FL
![]() Still not going in i am open to ideas and suggestions tools used a jack and a crowbar so far and nothing Also while down there i discovered my flex pipe was broken =(
#10 | ||||
So mote be it
Well my experience isnt going to help, I had the opposite problem. Those two points were too close and I had to push the engine away. Along with my floor jack and a block of wood under the tranny/engine to support/move the weight while trying to get it to line up
If you raise the car higher/lower, will that create a pivot and let gravity push those two points closer? (I'm trying to orientate myself to that picture, front of the car is to the right, correct?) Do you have any ratchet straps you can hook around the subframe and engine to pull those two points closer? No idea if either of those are viable or dumb...just throwing out ideas. I'm getting the impression you are working on this yourself. Glad you stopped on it last night, sounded like it had be super frustrating (I know i had to sleep on mine after not getting it done the night i tried to install it.) |
| Thread Tools | |
| Display Modes | |
