positive camber after installing coil overs - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-08-2013, 09:51 PM   #1
israel
israel's Avatar
Fan#: 102083
What I Drive: 2004 svt focus
FF Reputation: 1 israel Good Standing Member
ok like the tittle says
i just got coilovers installed (ksport kontrol pro) but there's an issue, i have a little of positive camber instead of negative.
also there is a popping noise coming from the front driver side and it is not the ball joints because that was replaced at the same time the coil overs were installed.
any ideas whats going on here?
thanks in advance
israel is offline
Old 01-08-2013, 10:23 PM   #2
6SPD_soul
6SPD_soul's Avatar
Fan#: 53637
What I Drive: 2003 Comp Orange EAP SVT
Points 2,489, Level 30
Points: 2,489, Level: 30 Points: 2,489, Level: 30 Points: 2,489, Level: 30
Level Up 26% Completed
FF Reputation: 24 6SPD_soul Great Standing Member
You might have to progress from lolspeak to get any meaningful response here, but I'm going to say something is very wrong if you somehow ended up with positive camber after lowering you car. Talk to the Texans that installed your suspension because if you got positive camber they did something terribly wrong.
6SPD_soul is offline
Old 01-08-2013, 10:26 PM   #3
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,233, Level 100
Points: 138,233, Level: 100 Points: 138,233, Level: 100 Points: 138,233, Level: 100
Level Up 0% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
Buy-Sell-Trade Rating: (11)
He had a shop do it. Is it lowered any or still at the stock height?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-08-2013, 10:28 PM   #4
israel
israel's Avatar
Fan#: 102083
it is lowered, no wheel gap in the front, and about half an inch wheel gap in the back
israel is offline
Old 01-08-2013, 10:35 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 53%
How much positive camber do you have? Do you have an alignment sheet from the alignment? Did you replace your sway bar links as well at the same time? Those are known to cause the popping noise though wouldn't have anything to do with the positive camber issue. Does it have upper camber plates on the coil overs? If not then I would try those out to dial it in where it needs to be, that's if everything was installed correctly.
Moderator for
Technical Chat
Old 01-08-2013, 10:53 PM   #6
israel
israel's Avatar
Fan#: 102083
its not too much of positive camber but i can tell there is some, yea sway bar link and ball joints were replaced at the time the coilovers were installed, umm no i bought them used n didn't come with that....could that b the problem?
israel is offline
Old 01-08-2013, 11:02 PM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 53%
So you didn't get a alignment done with them? They usually don't come with upper camber plates that's a separate part I think? Did you replace the upper strut mounts?
Moderator for
Technical Chat
Old 01-08-2013, 11:13 PM   #8
israel
israel's Avatar
Fan#: 102083
I did but i dont have the sheet, oh ok i thought i was ripped off for a second lol, no but i will take a look at that.
israel is offline
