17x9 wheels - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-08-2013, 03:07 PM   #1
yeahdudeguy
yeahdudeguy's Avatar
Fan#: 57563
What I Drive: Silver SvtF ZX5
Points 1,757, Level 24
Points: 1,757, Level: 24 Points: 1,757, Level: 24 Points: 1,757, Level: 24
Level Up 57% Completed
Level up: 57% Level up: 57% Level up: 57%
FF Reputation: 0 yeahdudeguy Newbie
17x9 wheels
So to start off I am not a wheel type of guy my i know nothing about this subject =)
So i have seen a few nice svt around my area with 17x9 mustang cobra reps and now i want them but i dont know where to start looking spec wise.I dont know what off set i would need or if i would need to get spacers roll or pull my fenders a bit or if i would have to adjust camber or buy something aftermarket to make this fit proper.
the one thing i know is where to buy the wheels i just dont know what offset i should be getting
thanks
yeahdudeguy is offline
Old 01-08-2013, 03:50 PM   #2
Nickgt40
Wheel King, Bow Down
Nickgt40's Avatar
Fan#: 40924
Location: Annoying the Liberals, California, United States
What I Drive: 01 Black ZX3, 09 FSWerks SEMA Coupe
FF Reputation: 19 Nickgt40 Great Standing Member
You should avoid 17x9 wheels like the plague. Especially those, and for a few reasons.
1) The offset is all wrong, they stick out WAY past the fenders.
2) They're heavy, upwards of 25lbs
3) You need to run 205/40/17 tires to even get them close to fitting.
4) You'll need to purchase a set of coilovers, camber plates, camber arms and adjustable toe arms... and again, that will only get them close to fitting.
5) In case you missed it before, they don't fit. 17x9 et24 is far from optimal.
Feb 2011 Ride of the Month ~ 2011 Hatch Nation Hatch of the Year ~ 2011 Focus Fanatics Ride of the Year!
Hatch Nation #2
Nickgt40 is offline
Old 01-08-2013, 04:24 PM   #3
yeahdudeguy
Fan#: 57563
good to know i would not want to invest a few hundred just to fit some wheels what whats my next option 17x8?
Old 01-08-2013, 04:46 PM   #4
Nickgt40
Nickgt40's Avatar
Fan#: 40924
Oh it would cost you the better part of $1k to get all of that suspension stuff together, and that's not including wheels and tires.
What suspension do you have now? 17x8s are definitely easier to fit but require you to be a bit lower and a lot stiffer than stock unless you're wanting to run 205 series tires.
Hatch Nation #2
Nickgt40 is offline
Old 01-08-2013, 05:25 PM   #5
yeahdudeguy
Fan#: 57563
i dont have much done but i do have it dropped with a Eibach Pro-System kit with a 1.2inch drop
Old 01-08-2013, 05:35 PM   #6
Nickgt40
Nickgt40's Avatar
Fan#: 40924
Is that as low as you're willing to go?
You can go with a 17x8 but get something et40-42 with 215/40/17 to keep from rubbing a lot. If you'd like a meatier tire, a 17x7.5 et 35 with a 215/45/17 will work too.
Hatch Nation #2
Nickgt40 is offline
Old 01-08-2013, 07:58 PM   #7
focusmaniaczx3
I need BOOOOST!!!!!!
focusmaniaczx3's Avatar
Fan#: 55157
What I Drive: zx3 turbo, kia soul, 71 chevy c/10
Points 15,082, Level 79
Points: 15,082, Level: 79 Points: 15,082, Level: 79 Points: 15,082, Level: 79
Level Up 47% Completed
Forum Activity 5%
FF Reputation: 35 focusmaniaczx3 Great Standing Member
Buy-Sell-Trade Rating: (14)
why do you have to go low to run a 17x8? im on factory SVT springs and had/have no problem. optimal offset for a 8 inch wide wheel would be between 41mm and 43mm. that would put the wheel as close to the inner shock as possible without rubbing the shock and it would come close to tucking it in the fenders. it still wouldnt quite tuck under the fenders though which means you would still rub a bit when you hit a bump really good. a slight rolling of the fenders would probably solve that. i just finished doing a fair bit of research into this subject because i am looking for wider wheels for better traction.
the cobra wheels you saw rolling around were likely factory 5 spoke SVT focus wheels. they are 17x7 et 45 i think.
think of offset like this. the lower the number the more the tire is going to stick out of the fender wells. the higher the number the more the wheel is going to be tucked up inside the fenders.
focus-power P&P head $1100
focus-power DIY turbo kit $1495
tom's first time in Vegas? PRICELESS!
Originally Posted by 1turbofocus
I love this big little city HOOTERS !
Every time you drink a beer somewhere an ugly woman becomes beautiful, so get to it!
focusmaniaczx3 is offline
Old 01-08-2013, 08:19 PM   #8
Nickgt40
Nickgt40's Avatar
Fan#: 40924
The factory SVT Focus wheels are ET49.
And you on stock suspension are about an inch higher than he is, so even though your spring rate isn't as high the likelihood of your tire coming into contact with the fender is less likely than his is. The idea of going lower is it will add natural camber while also increasing spring rate and ergo travel.
And I'll stick to my suggestions of ET40-42, not that there's that much difference between your suggestion, but ET43 doesn't work with some coilovers in the rear so 42 is a more universal guide to fit.
If you want to fit more wheel under your car that's great, I've got 17x8.5 ET39 wheels with spacers front and rear to ensure fitment. I run 215/40/17 tires with no issues, although I run more camber than the typical focus owner.
Hatch Nation #2
Nickgt40 is offline
Old 01-09-2013, 09:47 AM   #9
jinstall
Deutsche Arsche
jinstall's Avatar
Fan#: 9730
What I Drive: 01 ZX3RACECAR/04 ST170/13 FST2
Points 2,827, Level 32
Points: 2,827, Level: 32 Points: 2,827, Level: 32 Points: 2,827, Level: 32
Level Up 52% Completed
Forum Activity 8%
FF Reputation: 4 jinstall Good Standing Member
I run 8 up front and 9 in the rear. I do not recommend 9 unless you want to replace tires every 10k or so.
2001 Focus ZX3-Ours FREED & DELIVERY ON FRIDAY!
2010 Renault Clio 1.2 16V in Germany-Hers FOR SALE
2004 SVTF EAP/ST170-Mine
2013 Focus ST2 TS NAV SUNROOF-Hers
jinstall is online now
Old 01-09-2013, 10:23 AM   #10
yeahdudeguy
Fan#: 57563
i have the stock svt rims not in love i wanted something wider with some stance to it i wouldnt mind replacing tires every 10k i dont put 10k a year on the car to begin with more like 5k just to work and home take the civic on long trips with the wife and kids i rarely use the svt for anything
