SPI struck me as well - Rebuild thread - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-12-2013, 09:53 PM   #11
WrenchTurnerDave
WrenchTurnerDave's Avatar
Fan#: 98540
What I Drive: 2003 Green Focus SE (2.0L SPI)
FF Reputation: 3 WrenchTurnerDave Good Standing Member
Malim...do not reuse that connecting rod, or wristpin. They are definitely bent. Only slightly can make a difference, trust me.
Also, other responder was correct, exhaust seats hardened, have new seats pressed into intake and have metal "gnurled" over them to prevent this from happening again.
Also, I've kept up this whole time, you are doing a great job. Don't listen to users like Top Ace, you're doing fine.
Last edited by zetecDon; 01-14-2013 at 11:44 PM. Reason: Removed unnecessary response.
WrenchTurnerDave is offline
Old 01-13-2013, 12:08 AM   #12
lmcd314
lmcd314's Avatar
Fan#: 90550
What I Drive: 00 spi-sold, 2003 cd-silver SVT zx5
Points 904, Level 16
Points: 904, Level: 16 Points: 904, Level: 16 Points: 904, Level: 16
Level Up 4% Completed
FF Reputation: 1 lmcd314 Good Standing Member
this is what i used
i bought this piston, connecting rod and rings setup already assembled, yes it costs a little more, but it sure was convenient, ( http://www.ebay.com/itm/2-0-Ford-Foc...3&cmd=ViewItem )
then i bought this assembled head http://shop.advanceautoparts.com/web...ead#fragment-4
saved some money with: http://www.retailmenot.com/view/advanceautoparts.com
lmcd314 is offline
Old 01-14-2013, 04:51 PM   #13
malim
malim's Avatar
Fan#: 55004
What I Drive: 2007 Ford Focus ST - Black
Points 972, Level 16
Points: 972, Level: 16 Points: 972, Level: 16 Points: 972, Level: 16
Level Up 72% Completed
FF Reputation: 4 malim Good Standing Member
Hey. Im having an issue now with parts. I wanted to order some parts from ROCKAUTO, but they took off Cylinder Head Bolts & Oil Pan Gasket, claiming that they might not fit the vehicle due to several returns they had.
Can you guys verify whether you used Fel-Pro #72672 Head bolts and Fel-Pro OS30915R Oil Pan Gasket on the SPI ?
Thank you.
malim is offline
Old 01-14-2013, 05:21 PM   #14
lmcd314
lmcd314's Avatar
Fan#: 90550
yup
I'm not sure of the model #'s but I used the felpro set from advanced auto. It has been running fine since September. Don't skimp on the head gasket. I paid about $130 for the set.
lmcd314 is offline
Old 01-28-2013, 11:24 AM   #15
a_2000_se
a_2000_se's Avatar
Fan#: 62964
What I Drive: 2000 SE SOHC SPI, Compression @ 164
Points 4,699, Level 43
Points: 4,699, Level: 43 Points: 4,699, Level: 43 Points: 4,699, Level: 43
Level Up 75% Completed
Forum Activity 5%
FF Reputation: 15 a_2000_se Great Standing Member
A little late to the dance here but... it looks like you got your questions answered. Good advice on replacing 'yes' replacing your #4 rod. It's been stressed and probably bent.
Hopefully this may not be too late - There "is" an aftermarket manufacturer with a 'new' cast for the SPI SOHC head that supposedly addresses the dropped valveseat problem and makes it a non-issue. A thread somewhere here in this section during the last year was started on this topic.
Member of the Dropped Valve Seat Club.
Replaced #4 Piston, Rings, Rod+Bearings, AERA Re-Manufactured Cylinder Head and a light Hone. Then CLEANED the hell out of everything.
60k+ miles.
a_2000_se is offline
Old 02-12-2013, 11:15 AM   #16
Donnyd21
Fan#: 109211
What I Drive: 2002
FF Reputation: 1 Donnyd21 Good Standing Member
Use the coupon codes and get it cheaper!
I HAVE GOOD USED OEM PISTON AND ROD ASSEMBLIES FOR ALL 2.0L SPI ENGINES (FOCUS, ESCORT AND TRACERS)!! PM ME.
Donnyd21 is offline
Old 02-13-2013, 11:02 AM   #17
lmcd314
lmcd314's Avatar
Fan#: 90550
Yes, retailmenot.com i saved at least $100 in parts
lmcd314 is offline
