idle adjust screw uses - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-07-2013, 08:43 PM   #1
zpellicone
Fan#: 105007
What I Drive: 2001 Pitch Black ZTS
FF Reputation: 1 zpellicone Good Standing Member
I know the idle screw is not meant to be touched but is it possible to adjust it just a little to allow more airflow into the engine for a smoother idle in drive. I dont have a terrible idle but I feel like it would benefit from alittle more air. Can u change the screw slightly to do this?
zpellicone is offline
Old 01-07-2013, 09:12 PM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
The IAC controls your idle speed.
If you open the throttle blades at idle, the IAC will reduce it's airflow to compensate.
You have something else going on, probably the PCV.
elsolo is offline
Old 01-07-2013, 10:25 PM   #3
Elizabeth
Elizabeth's Avatar
Fan#: 89280
Points 14,339, Level 77
Points: 14,339, Level: 77 Points: 14,339, Level: 77 Points: 14,339, Level: 77
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 19%
FF Reputation: 15 Elizabeth Great Standing Member
From use the throttle stop screw may 'settle' or wear slightly and then the throttle blade may stick closed a little. moving it can stop the sticking.
that is about the only reason to adjust the screw.
Elizabeth is offline
Old 01-08-2013, 01:46 AM   #4
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
More likely for carbon to build up on the butterfly edges to block the air crack. Regardless, the PCM will simply reset the idle right back where it belongs.
amc49 is offline
Old 01-08-2013, 01:57 AM   #5
freemind
Vince your Moderator
freemind's Avatar
Fan#: 67513
Points 6,606, Level 53
Points: 6,606, Level: 53 Points: 6,606, Level: 53 Points: 6,606, Level: 53
Level Up 28% Completed
Forum Activity 49%
Buy-Sell-Trade Rating: (23)
I just installed a Focus Central TB and it revs at 1600-1800 RPM's the screw is just touching the plate. The return spring is pretty rusty and weak.
So to the OP, what does the return sping look like? Worn? Rusty?
Hatch Nation #140
Caeci caecos ducentes
freemind is offline
Old 01-08-2013, 03:19 AM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,507, Level 100
Points: 138,507, Level: 100 Points: 138,507, Level: 100 Points: 138,507, Level: 100
Level Up 0% Completed
Forum Activity 60%
Activity: 60% Activity: 60% Activity: 60%
Buy-Sell-Trade Rating: (11)
Any adjustments you make will not last, the computer will compensate and return the idle to the programmed idle speed. Why would you want to change it anyways? If it's running good there is no need to. If it's feeling a little rough in drive you should probably check or change your motor mounts. Those are one of the number 1 reasons for vibrations, not idle speed.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
