2013 fog lights - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-24-2013, 10:46 PM   #21
thejordan
thejordan's Avatar
Fan#: 107706
What I Drive: 2013 SGM Focus 5 Speed
Points 1,041, Level 17
Points: 1,041, Level: 17 Points: 1,041, Level: 17 Points: 1,041, Level: 17
Level Up 41% Completed
Level up: 41% Level up: 41% Level up: 41%
FF Reputation: 4 thejordan Good Standing Member
Originally Posted by Matasickle View Post
Look what arrived.
keep us posted!
thejordan is offline
Old 03-11-2013, 08:29 AM   #22
Matasickle
Matasickle's Avatar
Fan#: 77627
What I Drive: MK3 SGM SE
FF Reputation: 2 Matasickle Good Standing Member
Originally Posted by HoneyBadger View Post
Let us know how it goes!
Originally Posted by Duffman355 View Post
i like how you embraced the whole guinea pig mentality lol. Good luck though for real
Originally Posted by Juicedz View Post
I pray they work. I have a 2013 se and would like aftermarket fogs that eliminate the nightmare that a previous member went through trying to duplicate a factory install job. The only problem I foresee is hooking up the harness to the "factory switch". You'll probably have to fabricate your own. Subscribing
Originally Posted by thejordan View Post
keep us posted!
Well.. The deed is done.. I will write up my experience in a bit..
Matasickle is offline
Old 03-11-2013, 08:57 AM   #23
Creative
Creative's Avatar
Fan#: 108024
What I Drive: 2013 Ford Focus
Points 3,615, Level 37
Points: 3,615, Level: 37 Points: 3,615, Level: 37 Points: 3,615, Level: 37
Level Up 77% Completed
FF Reputation: 3 Creative Good Standing Member
Experience was not that hard
All you guys need to do is buy a new light switch that has fog option run the fogs inside to that the run a relay and fuse in there which I wired into the fuse box. Took about 3-4 hours for total time. Running the wires into the cabin was the hardest part I'd say
Originally Posted by Dialed View Post
Let's be honest guys, car modding is not synonymous with warranty-covered cars.
As the old saying goes, you have to pay to play.
Creative is offline
Old 03-11-2013, 09:28 AM   #24
Matasickle
Matasickle's Avatar
Fan#: 77627
Where did you end up running yours?
Old 03-11-2013, 10:56 AM   #25
OPsDad
OPsDad's Avatar
Fan#: 108661
What I Drive: 2014 Fusion Titanium AWD Moonroof
FF Reputation: 2 OPsDad Good Standing Member
I'm unclear about a detail. Did you just wire them, or did you find a way to use the OEM harness?
SR #265 | "Quia currus certatus, inferius"
13 Focus Ti Sedan w/Handling Pkg, MFT Sony 10 NAV, Leather
13 Focus SE HB Sterling Grey, 201A, Leather
06 F350 6.0L DRW King Ranch, Sunroof, Rhino Bed Liner, 4" MBRP Turbo Back, AirRaid, Edge Chip w/Pyro
OPsDad is offline
Old 03-26-2013, 02:52 AM   #26
jello_bob
Fan#: 107882
What I Drive: 2013 Ruby Red SFE
FF Reputation: 1 jello_bob Good Standing Member
Details??
jello_bob is offline
Old 03-26-2013, 10:41 PM   #27
Creative
Creative's Avatar
Fan#: 108024
Mine runs from my fog lights to the inside of my car. I bought a light switch off a 2012 that has foglight compatibility. From the switch I wired it to the battery and to the foglights. The battery location in taped into the wire that connects and runs to fuse box. I will be changing my setup once my hids come for fogs and probably running a tap to th alternator to get a full 12v charge constantly.
Creative is offline
Old 06-04-2013, 12:36 PM   #28
ptbish
ptbish's Avatar
Fan#: 114734
What I Drive: 2013 Ruby Red Focus SE, HB
Points 22, Level 1
Points: 22, Level: 1 Points: 22, Level: 1 Points: 22, Level: 1
Level Up 43% Completed
FF Reputation: 1 ptbish Good Standing Member
simplefogs?
Is there a way to install oem fogs and maybe just wire them to come on when the ignition is on......I would actually prefer them to be on all the time. Where would you tap in the hot, and would you use the wiring harness previously mentioned? I am looking for the simplest way to add fogs with limited electronic skills.
ptbish is offline
Old 06-11-2013, 12:09 PM   #29
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
I have a 2013 ford focus se that came with out fog light I read a write on the 2012 s model that did the install and noticed it was a big headache to do the relays and harness in fuse box, I wanted to know if there is an easier way to wire them in like hard wiring them into the headlight harness.
Anyone know the part number for wiring harness if I need it?
Did you ever get an answer to your question? Is there a way to wire the fogs to the head light harness? What did you end up doing?
ptbish is offline
Old 06-26-2013, 10:18 AM   #30
ptbish
ptbish's Avatar
Fan#: 114734
Points 22, Level 1
I bought the same kit from Blinglights. I had some difficulties though. Had to mount the light on the bezel itself using wire, a little adhesive putty ( just to keep the lens from scooting around on the back side of the bezel), and some stainless wire run through some holes I drilled in the edge of the bezel. I drilled the holes on the portion of the bezel that is hidden. I did all this because neither of the mounting methods described in the included instruction were applicable to a MK3 focus. Irritating, considering that Blinglights is advertising these as a fit for this car. The only "fit" is that they will go in the space available. Also, I had to lenghten the harness between the two lights by 16"; about 30 min of soddering and rapping. Instead of running the hot to the battery, i found an open fuse space on the box under the hood, which is hot when the ign. is on, so that I can just leave the provided toggle switch "on " all the time. (cont.)
ptbish is offline
