Old 01-06-2013, 05:31 PM   #1
merkur
Fan#: 78072
What I Drive: 2002 white zx5
FF Reputation: 1 merkur Good Standing Member
Iac valve
Hey guys
i have a constant stalling problem on my 2002 ford focus zx5. I am told the iac valve may be clogged. We cleaned the maf sensor but stalling persists
my questions is: Where is the iac valve located?? How do you access it -from the top or the bottom of the vehicle ---what tools do i need to change it and can the valve be cleaned? Please let me know as the car stalls at every stop i make
thanks guys
jeff in atlanta
merkur is offline
Fan#: 1
Old 01-06-2013, 05:50 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
FF Reputation: 6 Magus2727 Good Standing Member
Its on the intake manifold. back side about middle. Below the TB and when installed on the motor above the starter. Its a PITA to get to but I have found its best to go from the bottom. you have to do most of it by feel and don't have a whole lot of room to swing wrenches so is a little slow going to back out the I believe 10mm (two) bolts.
Their is a write up IIRC on the cleaning of this. think you basically just use Carb cleaner and some Que tips and let it dry then re-install. hardest part is putting the gasket back on since you cant really see what your doing.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 01-06-2013, 08:31 PM   #3
amc49
Fan#: 96610
FF Reputation: 15 amc49 Great Standing Member
If it stalls everytime you let motor fall to idle motor may be dead. Indicator would be problem showing up all at once, carbon buildup generally gets bad to worse.
amc49 is offline
Old 01-07-2013, 03:44 PM   #4
merkur
Fan#: 78072
HEY FOCUS ROOKIE
thanks for the info.. lol -- I moved from Chapel HIll to Atlanta. I miss it. whereabouts are you there?? Plan on revisiting soon
Jeff
merkur is offline
Old 01-07-2013, 11:59 PM   #5
my_beautious_ZX3
Fan#: 32386
What I Drive: 2002 charcoal XZ3
FF Reputation: 5 my_beautious_ZX3 Good Standing Member
peruse this thread. Photos on page 3.
http://www.focusfanatics.com/forum/showthread.php?t=262990
"I'm jealous of girls because they get to wear dresses." (Todd Flanders)
my_beautious_ZX3 is offline
