timing cover - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 04:56 PM   #1
elchicharo2000
Fan#: 107884
What I Drive: 2012 focus
FF Reputation: 1 elchicharo2000 Good Standing Member
Question timing cover
Hello everyone thanks for let me join ur forum, a have a problem I buy a 12 focus and the timing cover is broken some body take the cover out and try to start the car but I noticed the ballancer pulley no have a line how I put on time because the other people can't due I want to try thanks for ur help
elchicharo2000 is offline
Old 01-06-2013, 06:56 PM   #2
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,369, Level 61
Points: 8,369, Level: 61 Points: 8,369, Level: 61 Points: 8,369, Level: 61
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 42%
Activity: 42% Activity: 42% Activity: 42%
Welcome to the forum!!
I am not sure I understand what your saying, you may need to be more clear and divide up your sentence structure better. This will help people answer your question rather then spending the time trying to understand what you asked.
So you have a 2012 Focus. Your saying some one pulled the valve cover off and adjusted your timing? and you want to put the timing back to stock?
I am not familiar with the 2012's and their function but unless a lot changed you cant manually adjust the timing. a Chilton or Haynes manual will be of a good asset and will give you torque ratings and the order to tighten it down.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 01-06-2013, 07:59 PM   #3
amc49
Fan#: 96610
Points 3,258, Level 35
Points: 3,258, Level: 35 Points: 3,258, Level: 35 Points: 3,258, Level: 35
Level Up 39% Completed
Forum Activity 3%
Electronically controlled engine, you CANNOT adjust the timing AT ALL. Car retimes itself every time it starts up.
amc49 is offline
Old 01-06-2013, 11:23 PM   #4
elchicharo2000
Fan#: 107884
hello how r u on my post I said Timing cover no valve cover, the problem is went the other people take the balancer pulley they no mark the position for the pulley and now the car no run is sound like of on time, I try to put on time but the crank and cam no mach the position and I don't no how to move
Old 01-07-2013, 06:57 AM   #5
anarchy0392
Fan#: 102873
What I Drive: 2002, Silver, SE
Points 1,567, Level 22
Points: 1,567, Level: 22 Points: 1,567, Level: 22 Points: 1,567, Level: 22
Level Up 67% Completed
FF Reputation: 2 anarchy0392 Good Standing Member
Buy-Sell-Trade Rating: (9)
What?? Are you saying that the timing cover is off and that is the reason it's out of time? Have you tried goggling it?
anarchy0392 is offline
Old 01-07-2013, 05:25 PM   #6
amc49
Fan#: 96610
Forum Activity 3%
That may be one of the ones with no keyway, the pulley can be put anywhere.........someone will have to reset it back up.
amc49 is offline
Old 01-07-2013, 10:15 PM   #7
elchicharo2000
Fan#: 107884
correct they no have keyway that's the problem I whant to try to fix can somebody now how thanks
Old 01-07-2013, 11:07 PM   #8
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,576, Level 30
Points: 2,576, Level: 30 Points: 2,576, Level: 30 Points: 2,576, Level: 30
Level Up 84% Completed
Forum Activity 8%
You'll want a service manual.
In a nutshell, you'll be doing 90% the job as a timing belt replacement on a car with a timing chain. You gotta get the tools to locate TDC, the tool to hold the cams in time, and new friction washers for the crank mounted sprocket and pulley.
elsolo is offline
