help needed in the uk (1.8 TDCI) - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 01:54 PM   #1
scunnylad
Fan#: 108127
What I Drive: 2002 white ish mk1 1.8tdi
FF Reputation: 1 scunnylad Good Standing Member
hi all, sorry if my terms are different as im from uk and somethings may not translate if you get me,
i do have some car mechanical knowledge and will give everything a go but cambelts lol, Ive just bought a 2002 mk1 focus with a 1.8 tdi engine? (sure its the 90ps one) it has a few problems which may be easy to fix but thought i would ask the pros before i go all gung-ho and remove everything.
Firstly the central locking doesnt work, ive put a new battery (a cr2032 which i think is correct) but nothing, i read about the re-programming by turning on and of the ignition but i cannot get it to beep as it should? Also if i unlock the drivers door it only opens the drivers door but if i unlock the passenger door it unlocks all except the drivers door.
The fuel gauge is tempermental, one min its on full (which it is as ive tanked it) then the next its as low as it can get with fuel light on. It was on half tank yesturday and went from empty to full to half tank to empty, the bulb is also out behind the gauge (dont know if this is related) would this be clocks or sender? is there any way to test one of the two? how hard is removing the clocks as the bulb will deffo need changing, and how easy is access to the sender unit ?
It has a whiring from the engine i think it may be the aux belt idler pulley but it could as be the bearing what is on the alternator shaft? Does that usually become noisey or would i be correct in thinking its usually the pulley.
It has got an engine oil leak ( for over 3 years as i have previos mots) Its on the front of the engine but from what i can see its quite high up, does any particular seal or gasket go? ive heard about cambelt cover oil leaks but looks worse over to the gearbox side.
the passenger door wont open from the outside - is this just a simple bar fallen of or do fords have adjustments, also how hard of a job is it to remove the doorcards?
sorry its long and theres alot of problems but once these are out the way i can focus (no pun) on the outside and bodywork
regards sam
scunnylad is offline
Old 01-06-2013, 04:02 PM   #2
Capt. Obvious!
Fan#: 108055
What I Drive: 04 ZX3 S/C, 87 VW cabby, 98 Opel
FF Reputation: 1 Capt. Obvious! Good Standing Member
Most of the people on here are from the US, we don't have the diesel models in the US, all of ours are gas (petrol) unless I'm mistaken. So it is likely that the problems you are having are not familiar to most of us.
The fuel guage could be a number of things, from bad grounding wires to a bad sending unit, or even a bad gauge cluster. changing the sending unit shouldn't be too hard. check under the back seat cushion to see if there is a panel to give access to the fuel pump/sending unit, If not then you just have to drop the tank. I'm not really sure on these cars, either way it's not very difficult. (just make sure the tank is almost empty if you have to drop it, a full tank can be heavy and all that gas sloshing about can make it hard to handle)
The passenger door is likely just something popped loose.
I'm afraid I really don't know about the other stuff, I'd suggest getting a shop manual and giving it a go.
Capt. Obvious! is offline
Old 01-06-2013, 05:58 PM   #3
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
Points 27,933, Level 98
Level Up 59% Completed
Forum Activity 10%
Moved to General Technical Chat. This is where you'll get the best maintenance and repair advice. We do have international members who frequently help out in that forum. I'll slightly change the title so they will be attracted to answer.
Thanks for posting!!!
Don't worry about terms, some of us are good at translating British to American English.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
