#1 | ||||
Bad clutch master cylinder? Or slave cylinder?
Hey guys,
Lately I've been barely driving my car. It's been sitting in the driveway a lot over the past three months. About a week ago my clutch pedal started feeling very slippery, almost as if I had rain water on the bottom of my shoes from wet weather. The clutch pedal feels soft when pushed in, and my brake pedal definitely feels softer too (that might be because I asked the shop to top off the brake fluid reservoir when I got two new tires since I knew my brake fluid was low because of the leak.) I can still upshift/downshift perfectly fine. My transmission has no problem engaging gears, and the clutch is definitely not slipping. I looked under my car at the bellhousing, there isn't any signs of a leak. The pedal only starts to feel wet after driving around for 10mins after it's warmed up, and there's never a puddle of brake fluid on the carpet. I think I've narrowed it down to the clutch master cylinder going bad, but I just wanted everyone's thoughts/opinions. Does it sound like the CMC, or a slave cylinder? Does anyone know by chanced what the procedure for replacing a CMC is? I.E. How long does the whole job take? I think I'm going to order this CMC from RockAuto on Tuesday.. let me know what you think about it.
SoCal Crew #666
Remove Advertisements |
Fan#: 1
#2 | ||||
FF's Night Security
Your on the right track, if your pedal is wet it's from the brake fluid leaking onto it.
I started out with nothing and I still have most of it left Hatch Nation #15 (Ole' Yeller') & #150 (The SVT) Moderator for Technical Chat Zetec Performance Chat Southern Fanatics Chat |
#3 | ||||
Awesome, so it definitely sounds like the CMC and not the slave then, right? Would the loss in brake fluid also cause my brake pedal to go soft like the clutch pedal? I feel like it would since they share the same reservoir..
SoCal Crew #666
#4 | ||||
FF's Night Security
It could if you lost enough fluid, but I think they have a divider wall in them but I'm not 100% on that.
#5 | ||||
FF's Night Security
HERE is the how to on replacing it.
#7 | ||||
FF's Night Security
Thanks, and I hope it goes easy for you. I removed my drivers seat when I did mine so I could have some room to work and lay on the floor.
#8 | ||||
I recently did this and me only beeing 17 its a pretty easy instal just have fun bleeding the clutch that was the most difficult part if anyone can help explain it please do if not ill try my best in a little bit
#9 | ||||
I ordered my clutch master cylinder from Advance I got it the next day in the morning and by the afternoon it was installed. No more wet pedal :)
2003 Ford Focus SVT #1091 |
#10 | ||||
I was able to get my master cylinder cheaper at Orielly's when I factored in shipping costs. Normally though I buy stuff through RockAuto.
Bleeding the master cylinder can be a pain. See my write up on the pressure method I used. http://www.focusfanatics.com/forum/showthread.php?t=305412
2002 Ford Focus ZX5 2.0 Zetec MTX 2003 Ford Escape 3.0 Duratec |
| Thread Tools | |
| Display Modes | |
