Installing HIDs to 08 focus titanium facelift model - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 12:04 AM   #1
Kurtsmith2013
Fan#: 108102
What I Drive: 08 focus titanium grey
FF Reputation: 1 Kurtsmith2013 Good Standing Member
Hi there im new to this focus forum, i just bought a 08 focus and im after installing HIDs but i don't want to install them into headlight unit without projectors. I read up and cant seem to find a great deal of info. Some people say get these anti glare HIDs and you will be fine, also details on what bulb size and would i need error free bulbs? anyone with any info will be much appreciated. Thanks.
Kurtsmith2013 is offline
Old 01-06-2013, 12:22 AM   #2
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
What I Drive: 2006 silver zx4 ses
Points 4,176, Level 41
Points: 4,176, Level: 41 Points: 4,176, Level: 41 Points: 4,176, Level: 41
Level Up 13% Completed
FF Reputation: 3 sam fisher Good Standing Member
I wouldnt bother with that anti glare propaganda. Im pretty sure the only right way is to retro-fit . Check out theretrofitsource.com
And look at the morimoto mini kits. Alot of people use these on foci and say they are great kits and come with everything you need. Also theres a few good how-to writeups on here
Sent from my SPH-D710BST using FF Mobile
sam fisher is offline
Old 01-06-2013, 01:10 AM   #3
Kurtsmith2013
Fan#: 108102
Thankyou for your reply and that mini kit seems exactly what i was hoping for, do you know if there easy to fit? And will it come up bulb failure on my dash? Thanks again.
Old 01-06-2013, 01:30 AM   #4
sam fisher
I hate dents!
sam fisher's Avatar
Fan#: 103137
From what i have heard they are the easiest to work with , but im unsure of the bulb out indicator. Im sure someone will chime in who has done it on their 08 , if not try digging around on here in the lighting section for a write up on your model , and contact the writer or just comment in the thread. Sorry i cant give you more info lol , but im still waiting to retro-fit mine and i havent started my project yet
Old 01-06-2013, 12:36 PM   #5
gtferrari
gtferrari's Avatar
Fan#: 88110
Location: Grand Rapids/Big Rapids/Bangor/South Haven, MI
What I Drive: 2008 Vista Blue SES Coupe
Points 969, Level 16
Level Up 69% Completed
FF Reputation: 4 gtferrari Good Standing Member
using the search bar if you type in retrofit there should be quite a few write ups. i dont think you will find any that pertain to the uk focus, but the process is the same. basically take the light housing off the car and put it in the oven. bake at a certain temp and using some screw drivers and a putty knife you separate the housing. the projector slides in from the front into the spot the bulb used to be in. it all secures with a big nut on the back side of where the bulb went in. then all you do is either use some more heat or an adhesive and affix the lens back onto the housing. there is a special harness that prevents the bulb out indicator. its all plug and play. you dont need to do any cutting of the wires.
2008 Vista Blue SES Coupe 5spd FRPP Zx3B Suspension
5000K D2S Retrofit
130,000+ miles and still on factory brakes and clutch!
Rep Points dont add themselves
gtferrari is offline
Old 01-06-2013, 01:56 PM   #6
Kurtsmith2013
Fan#: 108102
Thanks for your replies, im deffo buying them projectors and hid kit next week, as the bi xenons are hid hi and low, the standard high beam bulb can i replace that with some sort of halo if wired upto side light bulbs with a relay?
