Purolator Oil Filter Question - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-06-2013, 04:20 PM   #11
scada
Fan#: 107778
What I Drive: 2013, Silver, Focus S
Points 310, Level 6
Points: 310, Level: 6 Points: 310, Level: 6 Points: 310, Level: 6
Level Up 20% Completed
FF Reputation: 1 scada Good Standing Member
Here are the specs of the 2 filters as. As you can see the filters are the same save for the height.
In any case my Malibu had an issue with the cam timing system. The tech at the dealer asked me about how long the oil was in the car. I showed him my test results from Blackstone Labs. His response to me was that there was no way the problem was caused by an oil related issue.
Part Number: PL10241
Specifications:
Anti-Drain Back Valve Yes Height 3.36
O.D. 2.98 Relief Valve P.S.I. 12-15
Thread Pitch UNF-2B Threads 3/4-16
Type of Filter Spin-on
Part Number: PL20195
Specifications:
Anti-Drain Back Valve Yes Height 4.74
scada is offline
Old 01-06-2013, 04:47 PM   #12
dan50
Fan#: 91789
What I Drive: 2012 SEL White Platinum 5 Dr 302A
Points 3,029, Level 33
Points: 3,029, Level: 33 Points: 3,029, Level: 33 Points: 3,029, Level: 33
Level Up 86% Completed
Forum Activity 3%
FF Reputation: 12 dan50 Great Standing Member
Specifications:
Specifications:
You've obviously done your homework and this makes perfect sense. My caution was directed at those who don't exercise the same level of diligence and may assume because a filter can be screwed onto an engine it's automatically appropriate.
dan50 is online now
Old 01-06-2013, 05:00 PM   #13
felixthecat
w/ my magic bag
felixthecat's Avatar
Fan#: 80663
Points 12,933, Level 74
Points: 12,933, Level: 74 Points: 12,933, Level: 74 Points: 12,933, Level: 74
Level Up 21% Completed
Forum Activity 99%
Specifications:
Specifications:
The motorcraft#'s are FL910 & FL400 which work great as does a FL842.
felixthecat is offline
Old 01-06-2013, 05:03 PM   #14
scada
Fan#: 107778
Points 310, Level 6
Thanks for the feedback. Good to bounce these ideas off others to make sure you are looking at it from all angles.
scada is offline
Old 01-06-2013, 05:27 PM   #15
scada
Fan#: 107778
Points 310, Level 6
I did a little more research. Looks like the FL400S has a 20psi bypass. The FL910S has a 14psi bypass filter.
Conclusion: Motorcraft FL-910S 14psi bypass
Purolator PL10241 12-15psi bypass
only use Purolator PL20195 12-15psi bypass if you want a longer filter.
scada is offline
Old 01-06-2013, 07:25 PM   #16
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
What 'bout a FL842 or similar?
Old 01-06-2013, 07:28 PM   #17
scada
Fan#: 107778
Points 310, Level 6
Does not look like an FL842 will work, no bypass valve.
scada is offline
Old 01-06-2013, 07:42 PM   #18
felixthecat
w/ my magic bag
Fan#: 80663
Forum Activity 99%
So the motorcraft FL842 or similar, does not have a bypass valve? Whats that mean? The oil is always flowing thru the filter? What? Right now I have a TG16 fram on, which is the same as a FL842.
Old 01-06-2013, 07:45 PM   #19
scada
Fan#: 107778
Points 310, Level 6
Looks like the Fram TG16 has a bypass valve. I am going by this on the FL842:
Brand:Motorcraft
Manufacturer's Part Number:FL842
Part Type:Oil Filters
Product Line:Motorcraft Oil Filters
Summit Racing Part Number:ACF-FL842
Oil Filter Style:Canister
Height (in):3.790 in.
Outside Diameter (in):3.660 in.
Filter Bypass Relief Valve:No
Anti-Drainback Valve:Yes
Thread Size:3/4-16 in.
Gasket Outside Diameter (in):2.834 in.
Gasket Inside Diameter (in):2.462 in.
Quantity:Sold individually.
scada is offline
Old 01-06-2013, 07:47 PM   #20
scada
Fan#: 107778
Points 310, Level 6
From the AutoZone website:
Part Number: TG16
Weight: 0.8 lbs
Anti-Drain Back Valve: Yes
By-Pass Valve: Yes
Diameter (in): 3.06
Height (in): 4.41
Filter Type: Oil
Filtering Material: Cellulose/Synthetic Blend
Gasket Material: Nitrile Rubber
Non-slip Grip: Yes
Oil Filter Style: Spin-On/Canister
scada is offline
