crappy fuel mileage - Page 6 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-15-2013, 12:37 AM   #51
amc49
Fan#: 96610
Points 3,369, Level 36
Points: 3,369, Level: 36 Points: 3,369, Level: 36 Points: 3,369, Level: 36
Level Up 13% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
PCM wouldn't care, 180 cam out is the same as dead on timing since both cam positions would still line up to TDC perfectly....................ANY TDC will work...............
amc49 is online now
Old 01-15-2013, 12:42 AM   #52
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
Yep, there is no compression stroke TDC until after the cams and belt are installed. Then there are two TDC's and one can be 180* off.
elsolo is offline
Old 01-15-2013, 02:18 AM   #53
tmittelstaedt
Fan#: 108093
What I Drive: 2001 Red Focus SE Street Edition
Points 233, Level 4
Points: 233, Level: 4 Points: 233, Level: 4 Points: 233, Level: 4
Level Up 66% Completed
FF Reputation: 2 tmittelstaedt Good Standing Member
Hmm - there is definitely a cam sensor in the later Zetecs - I'll have to check and see if there are 2 nubs on opposite sides of the end of the cam so that if it is 180 degrees out, the computer will still get the cam sensor pulses. Of course, the programmers _could_ could have put a routine in the computer to use the cam pulse even if it's coming in 180 degrees out...
tmittelstaedt is offline
Old 01-16-2013, 07:50 AM   #54
curtisparker82
Fan#: 108061
What I Drive: 2002 black zx5
FF Reputation: 1 curtisparker82 Good Standing Member
Changed ft rotors and the car rolls so much smoother...changeg pcv hose that was collapsed and the idle seemed to be better till i turned the heat off this morning and its still there...any ideas it seems to have a slight miss...there is oil in the intake you can see when you open the butterfly on the throttle body. Will that hurt it? If so how should i clean it out?
curtisparker82 is offline
Old 01-16-2013, 08:39 AM   #55
curtisparker82
Fan#: 108061
Originally Posted by tmittelstaedt View Post
i am going to guess that for some reason the engine is never moving to closed-loop operation. Drive it a while and get it nice and hot then take it to an auto parts store and have them scan it and look at all the sensor readouts and see if the engine is in closed-loop. If any of them look strange, then you may have a bad sensor.
The factory coil is going to be superior to any aftermarket coil. Get a factory coil from a wrecker and i'd bet the ilde miss goes away.
i have a gopoint cord and a ipod touch that works as a scanner how can i tell if it's in closed loop?
Old 01-16-2013, 09:02 AM   #56
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,624, Level 62
Points: 8,624, Level: 62 Points: 8,624, Level: 62 Points: 8,624, Level: 62
Level Up 58% Completed
Forum Activity 33%
Activity: 33% Activity: 33% Activity: 33%
If the motor is missing it should through a cell right? The closed loop question may be a good question to ask in the ECU / Tuning section where some one their may know. I think its usually determined by the head temp or coolant temp. but that still would not tell you 100%. I think you would have to look at the fuel profiles and see when it switches. Or it could be even easier then that and their is a signal that says if its open or closed loop.
Oil on the intake may have a very slight performance hit because the walls are not as smooth as they may have been but this is very typical of all cars. Make sure you have a filter of some sorts between the valve cover vent and PCV lines going into the intake tube. The factory one can get clogged up bad when your PCV valve goes bad.
You can clean it if you wish, by removing the intake manifold to do so is not that difficult but is also not something you just do for fun. What do people recommend as solvents to use if he does decide to clean the intake? You will then want to make sure it has fully dried before installing it back in.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-16-2013, 09:41 AM   #57
curtisparker82
Fan#: 108061
The last time it was missing when i had to get another coil it didnt throw a cel unless i power braked it to where it sounded like it was on the rev limiter @ 3k rpm...it's never really thrown a cel for anything not even when the alternator was going bad killing the engine at high rpm's...
Old 01-22-2013, 07:55 AM   #58
curtisparker82
Fan#: 108061
Found my ipod touch and hooked up my gopoint cable for the obdii 02 sensor is reading .1v and sensor 2 .8v fuel trim 1-2% and that was at idle with coolant temp 167deg
