crappy fuel mileage - Page 3 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-09-2013, 09:11 PM   #21
PWGuy
Fan#: 91777
What I Drive: 2003 Pitch Black ZTS Sedan
Points 2,131, Level 27
Points: 2,131, Level: 27 Points: 2,131, Level: 27 Points: 2,131, Level: 27
Level Up 88% Completed
Level up: 88% Level up: 88% Level up: 88%
FF Reputation: 1 PWGuy Good Standing Member
(see below)
PWGuy is offline
Old 01-10-2013, 10:32 AM   #22
curtisparker82
Fan#: 108061
What I Drive: 2002 black zx5
FF Reputation: 1 curtisparker82 Good Standing Member
Im running 215/45r17 tires they are only .5" over all od bigger? Would that kill the mileage? But i was running that before the mileage dropped from 23-18
curtisparker82 is offline
Old 01-10-2013, 10:54 AM   #23
PWGuy
Fan#: 91777
Originally Posted by Insaniac View Post
On my old '02 ZTS I was having a similar issue, where my MPG was steadily declining until it got as low as 21-23 MPG. My issue turned out to be my DPFE sensor (EGR pressure feedback).
I found an easy way to test it as well, simply go to your firewall and unplug the wiring pigtail from the DPFE sensor. If, after you unplug it, your MPG improves then you know it was the problem. >Here< is a photo showing the DPFE sensor near the brake fluid reservoir. After I unplugged mine, my MPG immediately went up to 25-27.
Another recommendation, if you do find your DPFE sensor is bad, don't cheap out on the replacement. I bought a generic chinese cheap-o replacement on eBay and it was worse for my MPG than the OEM one that went bad. Go with a genuine Motorcraft part, it will be more expensive but its worth the difference. After replacing mine with a quality part my MPG returned to the normal 27-29 MPG.
Was your Focus throwing a code to indicate DPFE failure?
PWGuy is offline
Old 01-10-2013, 02:43 PM   #24
Insaniac
Insaniac's Avatar
Fan#: 34327
What I Drive: 2003 ZX5 SVT
FF Reputation: 5 Insaniac Good Standing Member
At the very end of the process it gave P0401, but my gas mileage started dropping a few weeks prior to the CEL.
2003 ZX5 SVT #1345
CD Silver; Red Interior; Audiophile; Moonroof; HID's
Insaniac is offline
Old 01-10-2013, 03:18 PM   #25
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,393, Level 61
Points: 8,393, Level: 61 Points: 8,393, Level: 61 Points: 8,393, Level: 61
Level Up 81% Completed
Level up: 81% Level up: 81% Level up: 81%
Forum Activity 30%
Tire size can do cause different readings in MPG but will not cause a drastic difference "over night".
A larger diameter tire: 1 rotation = further distance traveled. So you will have actually traveled further than the OD reads. 0.5" difference not sure how much... their was a chart available that shows the MPH differences vs tire size. Larger tire may provide better freeway MPG, could have a slightly lower RPM to maintain a specified speed. City driving will cause higher MPG due to starting and stopping a tire with a larger rotational mass.
A smaller tire: 1 rotation = Less Distance. So you will have actually traveled less than the OD reads. Your actual MPG will be less, also freeway you will need to maintain a higher RPM to maintain the same speed.
Have you checked to see if you might have a dragging caliper or partially stuck drum? if you hit a pot hole and somehow had a huge change in your alignment that could be another possibility.... try testing the DPFE its easy to test.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-10-2013, 07:43 PM   #26
PWGuy
Fan#: 91777
I unplugged my DPFE this afternoon. The CEL came on when I pulled out of the garage this evening. I assume that's a good thing? Should I leave it disconnected to see if MPG decreases further to see if its 100% working or not?
PWGuy is offline
Old 01-10-2013, 07:54 PM   #27
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
does it run any better?
Hatch Nation #42
Old 01-10-2013, 08:42 PM   #28
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,343, Level 100
Points: 138,343, Level: 100 Points: 138,343, Level: 100 Points: 138,343, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
This
It's going to throw a code for what you unplugged, question is did it fix the problem?
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-10-2013, 10:53 PM   #29
PWGuy
Fan#: 91777
How will I know until I drive it for awhile and fill up with gas?
I think I noticed a little more vibration while stopped at lights but I can't say for sure. Honestly, the car "feels" the same when I drove it to a store and back earlier tonight.
PWGuy is offline
Old 01-10-2013, 10:54 PM   #30
PWGuy
Fan#: 91777
Apologies but my at doesn't misfire or anything - just consistent 17-19 mpg.
PWGuy is offline
