crappy fuel mileage - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-07-2013, 12:21 PM   #11
curtisparker82
Fan#: 108061
What I Drive: 2002 black zx5
FF Reputation: 1 curtisparker82 Good Standing Member
im gonna try and clean the IAC and see if that helps if not i guess i'll get a factory coil on payday
curtisparker82 is offline
Old 01-07-2013, 01:55 PM   #12
Dizle
Fan#: 103998
What I Drive: 2006 Black ZX3
Points 235, Level 4
Points: 235, Level: 4 Points: 235, Level: 4 Points: 235, Level: 4
Level Up 70% Completed
FF Reputation: 1 Dizle Good Standing Member
Best thing along with a general "tune up" I did for gas mileage is get an UltraGauge, google it give you instant feedback on miles per gallon, avg mpg and so much more!
Dizle is offline
Old 01-08-2013, 02:51 PM   #13
curtisparker82
Fan#: 108061
I did plugs, wires, coil, air filter less than 5k miles ago...running castrol 5w30 full syn...i wanna delete the egr but dont want the check engine light
Old 01-08-2013, 03:24 PM   #14
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,123, Level 60
Points: 8,123, Level: 60 Points: 8,123, Level: 60 Points: 8,123, Level: 60
Level Up 87% Completed
Level up: 87% Level up: 87% Level up: 87%
Forum Activity 23%
Activity: 23% Activity: 23% Activity: 23%
EGR should not impact your MPG in any way. Its an emission controlled device. Its to make your tail pipe emissions cleaner not reduce your MPG. When was the last time you checked tire pressure? Fuel filter? Possible partially clogged CAT? I know sometimes after sea foam in the intake or other aggressive quick intake cleaners could clog up the cat....
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 01-08-2013, 04:36 PM   #15
curtisparker82
Fan#: 108061
HAD THE CAT OFF IN THE SUMMER IT WAS CLEAN...CHANGED THE FUEL FILTER IN SUMMER CHECKED TIRE PRESSURE SUNDAY IT WAS 30-32 PSI....
Old 01-08-2013, 04:46 PM   #16
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 23%
have you checked the PCV hose or the PCV it self?
Hatch Nation #42
Old 01-08-2013, 10:41 PM   #17
Insaniac
Insaniac's Avatar
Fan#: 34327
What I Drive: 2003 ZX5 SVT
FF Reputation: 5 Insaniac Good Standing Member
On my old '02 ZTS I was having a similar issue, where my MPG was steadily declining until it got as low as 21-23 MPG. My issue turned out to be my DPFE sensor (EGR pressure feedback).
I found an easy way to test it as well, simply go to your firewall and unplug the wiring pigtail from the DPFE sensor. If, after you unplug it, your MPG improves then you know it was the problem. >Here< is a photo showing the DPFE sensor near the brake fluid reservoir. After I unplugged mine, my MPG immediately went up to 25-27.
Another recommendation, if you do find your DPFE sensor is bad, don't cheap out on the replacement. I bought a generic chinese cheap-o replacement on eBay and it was worse for my MPG than the OEM one that went bad. Go with a genuine Motorcraft part, it will be more expensive but its worth the difference. After replacing mine with a quality part my MPG returned to the normal 27-29 MPG.
2003 ZX5 SVT #1345
CD Silver; Red Interior; Audiophile; Moonroof; HID's
Insaniac is offline
Old 01-09-2013, 03:19 AM   #18
amc49
Fan#: 96610
Points 3,196, Level 34
Points: 3,196, Level: 34 Points: 3,196, Level: 34 Points: 3,196, Level: 34
Level Up 98% Completed
Forum Activity 53%
Activity: 53% Activity: 53% Activity: 53%
FF Reputation: 25 amc49 Great Standing Member
Errant EGR CAN cost mileage if causing misfire by being on at wrong time or too much, the misfire wastes fuel.............
amc49 is offline
Old 01-09-2013, 05:08 AM   #19
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 135,964, Level 100
Points: 135,964, Level: 100 Points: 135,964, Level: 100 Points: 135,964, Level: 100
Level Up 0% Completed
Forum Activity 65%
Activity: 65% Activity: 65% Activity: 65%
Buy-Sell-Trade Rating: (11)
You can always try replacing the O2 sensor. Rockauto has the NTK for a very good price. It's the OEM manufacturer and looks just like the motorcraft at a fraction of the cost.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-09-2013, 08:19 AM   #20
curtisparker82
Fan#: 108061
Originally Posted by magus2727 View Post
have you checked the pcv hose or the pcv it self?
changed pcv in the summer...haven't checked the hose real good but just looking at it it looks ok
