Main Cap #1 not flush? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-04-2013, 09:05 PM   #1
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,401, Level 61
Points: 8,401, Level: 61 Points: 8,401, Level: 61 Points: 8,401, Level: 61
Level Up 84% Completed
Forum Activity 30%
I have had this question for a bit and a recent complete tare apart and cleaning of the block ( got engine cleaning brushes to completely clean out the oil valleys and oil deposits).
The #1 main cap when installed is not flush with the side of the block. Is this normal? When installed and torqued down the #1 main cap (the one right next to the crank and oil pump) you can feel an edge the main cap "overhangs" by a few thousandths. I will measure when I get the chance.
But is this normal? I don't recall when I was doing the initial tare down.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is online now
Old 01-07-2013, 02:21 AM   #2
amc49
Fan#: 96610
Points 3,274, Level 35
Points: 3,274, Level: 35 Points: 3,274, Level: 35 Points: 3,274, Level: 35
Level Up 50% Completed
Forum Activity 11%
I wouldn't worry if correct cap and arrow facing right. Many engines do that. Fit oil pump up, it will clear all of that. Only full circle thrust bearing caps need to be dead even, this motor doesn't have that IIRC.
amc49 is offline
Old 01-07-2013, 09:59 AM   #3
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 30%
Thanks, I could not recall if the machined plate with the recessed screws on the oil pump actually mated up with the side of the block. but after looking at the pump (pictures mostly, my pump is stored somewhere in a pile of parts) and the gasket it looks like the block and the oil pump do not make contact on that surface.
I believe I have the caps in the right order. :-) #1 cap with the arrow pointing to the crank pulley. All Caps have arrow pointing towards crank pulley while going from #1 to #5 with #5 being next to the fly wheel.
I loosened the main cap and used a rubber mallet to gently tap the side of the main cap to see if it would "sit" more flush, but no movement. so re torqued down and will let it be.
Thanks for the help and reassurance for those who helped.
After looking at my disassemble pictures (below) Their is a good size gap between the pump and the main:
Hatch Nation #42
Old 01-07-2013, 10:10 PM   #4
ZXthrizzle05
TURBO ZX3
ZXthrizzle05's Avatar
Fan#: 24434
What I Drive: 2007 mazda 3 I sport, TURBO ZX3
Points 50,882, Level 100
Points: 50,882, Level: 100 Points: 50,882, Level: 100 Points: 50,882, Level: 100
Level Up 0% Completed
Forum Activity 4%
FF Reputation: 6 ZXthrizzle05 Good Standing Member
Buy-Sell-Trade Rating: (11)
that's normal
FF MODERATOR
RISE AGAIN EGGYOLK302 WHP 274 WTQ ZETEC CREW #271
RIFF CREW
ZXthrizzle05 is offline
Old 01-08-2013, 02:05 AM   #5
amc49
Fan#: 96610
Forum Activity 11%
There you go.........
amc49 is offline
Old 01-08-2013, 07:39 AM   #6
ZXthrizzle05
TURBO ZX3
Fan#: 24434
Forum Activity 4%
mine sat the exact same way. the pump sits a little away from the block for some reason but when I put everything back together and started it everything went fine no leaks
FF MODERATOR
RIFF CREW
