SVT Clutch Setup Issue - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Tech Discussions > Engine & Transmission Swap
Engine & Transmission Swap The place to chat about any engine and transmission swap.
Old 01-04-2013, 10:20 AM   #1
Bradwx
Fan#: 108045
What I Drive: 2000 ZX3, 04 Mazda6, 03 Avalanche
FF Reputation: 1 Bradwx Good Standing Member
My first post here. I am new to the SVT world but I want a 6spd car and cannot afford a Mini Cooper S.
Here is the history of the car. I got a 2000 ZX3 with a bad MTX-75 transmission. It was modified before I purchased the car. It has the header pipe and stainless exhaust, SVT rear brake set-up, and lowered suspension. The car has about 117k miles.
The engine and tramission are out and ready to be switched over.
I got a good deal on the SVT swap for the tranmission. It came with the getrag tranmission, shifter cables, shifter, axles, clutch and pressure plate. Since the clutch disc has minimal wear i decided to purchase a flywheel.
This is where the problem begins. The purchased flywheel seems to be an aftermarket SPEC aluminum flywheel and the LUK disc and pressure plate do not fit. I am almost certain the LUK clutch is correct. The disc is the correct width and fits the input shaft.
Does Anyone know if the SPEC setup uses a smaller clutch disc.
I will try to return the flywheel to the yard I picked it up from and try to get the correct LUK flywheel.
The SPEC flywheel is all aluminum (except the disc surface) and is very light.
Thanks
Brad
Bradwx is offline
Old 01-04-2013, 12:49 PM   #2
Bradwx
Fan#: 108045
After reading several posts.. I get the issue I am having. I bought a PRE-TSB Flywheel. Hopefully the yard will take it back and/or get me the correct one.
Bradwx is offline
Old 01-18-2013, 05:46 PM   #3
svtguy88
svtguy88's Avatar
Fan#: 13476
What I Drive: 2003 Infra Red SVT
Points 8,660, Level 62
Points: 8,660, Level: 62 Points: 8,660, Level: 62 Points: 8,660, Level: 62
Level Up 70% Completed
FF Reputation: 17 svtguy88 Great Standing Member
So you're putting the Getrag on a standard ZX3?
As you mentioned, there are two clutch/flywheel designs - pre and post TSB.
Hmm...I'm thinking you will run into some ECU problems once you have the clutch in.
svtguy88 is offline
Old 03-15-2013, 01:35 AM   #4
tjboston5676
tjboston5676's Avatar
Fan#: 71200
What I Drive: 2004 Sonic Blue ZX5 SVT
Points 2,179, Level 28
Points: 2,179, Level: 28 Points: 2,179, Level: 28 Points: 2,179, Level: 28
Level Up 20% Completed
FF Reputation: 3 tjboston5676 Good Standing Member
manual transmissions dont comminicate with the ecu, i dont beleive? other than the speed sensor
HATCH NATION #56
2004 Sonic Blue SVT!!! 2.5" orp and flex and trubendz catback, toms tune, steeda sts, custom intake, good ol motocraft copper plugs!
tjboston5676 is offline
Old 03-15-2013, 02:03 AM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,521, Level 100
Points: 140,521, Level: 100 Points: 140,521, Level: 100 Points: 140,521, Level: 100
Level Up 0% Completed
Forum Activity 55%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
The only problem would be the speed sensor, but I think you can get around that but I forgot how. I do know some have done the swap before.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 05-18-2013, 08:03 AM   #6
Bradwx
Fan#: 108045
Finally Got the Swap Done but now what
After working on other projects for other people I got the SVT trans in the ZX3. The swap was pretty easy but now I have a speed sensor issue. I can get the car up to 110 mph on the speedo which is about 35 to 40 mph. Whats worse is the computer cuts out the motor at 110mph.
Has anyone had this issue? Do I need to get the computer reflashed or is there an easier way around it. The wire harness hooked directly to the speed sensor on the svt trans and the wires were the same color and position on each connector.
Bradwx is offline
