sputtering and misfire - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-03-2013, 11:42 PM   #1
littleharv93
Fan#: 108029
What I Drive: 2000 flat black zx3
FF Reputation: 1 littleharv93 Good Standing Member
hello i drive a 2000 zx3 2.0 dohc zetec 5sp. ive had it for 2 years with very little problems now all of a sudden under heavy acceleration it sort of chugs every time i go to get on it and it usually happens in between the rpms of 2500 to 5000k if it does it then once i get into the higher rpms it goes away it also does it at idle if i give the car more than 1/2 throttle
i have already replaced the plugs and wires and the coil pack i am going to clean the throttle body and mass air flow senser any ideas on what could cause this problem
thanks
jordan
littleharv93 is offline
Old 01-03-2013, 11:50 PM   #2
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,370, Level 100
Points: 138,370, Level: 100 Points: 138,370, Level: 100 Points: 138,370, Level: 100
Level Up 0% Completed
Forum Activity 54%
Activity: 54% Activity: 54% Activity: 54%
Buy-Sell-Trade Rating: (11)
Welcome to the forum
Sounds like a fuel pressure issue to me. Your symptoms are very similar to the fuel pump going out. Very common on that model year. They redesigned the fuel pump and fuel pump canister after the 01' model year. You can try replacing the fuel filter sometimes that helps. Others may have more suggestions just need to wait for them to chime in
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-04-2013, 12:07 AM   #3
littleharv93
Fan#: 108029
well i already replaced the fuel filter but i shouldnt have out happened suddenly its been running like that for about 2 months and i just now got a chance to post on here
and to add it had done it for a little bit so i replaced the coil and then it stopped for a little bit then i just came back and has done it for about 3 weeks now after the little spurt where it had gone away after replacing coil
thanks
Old 01-04-2013, 12:11 AM   #4
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 54%
Hmm, check the coil pack wiring pigtail. The wires are known to get pulled out.
Moderator for
Technical Chat
Old 01-04-2013, 12:19 AM   #5
littleharv93
Fan#: 108029
ok will do the wires would just be loose then im assuming and on a new coil pack?
Old 01-04-2013, 12:36 AM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 54%
Yeah, if the coil pack is new check where the wiring go into the plug. They get pulled out, you can try pushing them back in but most of the time a replacement is better.
Moderator for
Technical Chat
Old 01-04-2013, 12:50 AM   #7
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,074, Level 27
Points: 2,074, Level: 27 Points: 2,074, Level: 27 Points: 2,074, Level: 27
Level Up 50% Completed
Forum Activity 5%
X2
Pics (and part numbers) in this thread: http://www.focusfanatics.com/forum/showthread.php?t=209172
BC_ZX3 is offline
Old 01-04-2013, 01:57 AM   #8
littleharv93
Fan#: 108029
i guess ill try it hope it fixes it i hate this car right now so much for doing it but its my babay haha so i have to fix it
Old 01-04-2013, 01:42 PM   #9
littleharv93
Fan#: 108029
well it worked pigtails were loose now i can actually get on it and enjoy my mods finailly that ive ben doing
thanks guys
Old 01-04-2013, 02:39 PM   #10
VinnyB
VinnyB's Avatar
Fan#: 97705
What I Drive: '03 Screaming Yellow EAP
Points 1,199, Level 18
Points: 1,199, Level: 18 Points: 1,199, Level: 18 Points: 1,199, Level: 18
Level Up 99% Completed
Level up: 99% Level up: 99% Level up: 99%
FF Reputation: 18 VinnyB Great Standing Member
Originally Posted by BC_ZX3 View Post
X2
x3
To the OP:
This wasn't the cause of the problem I had (I had a bad coil), but when replacing the coil, I inspected the pig tail, and saw that the insulation around the wires leading into the pigtail was cracked.
If it wasn't for law enforcement & physics, I'd be unstoppable.
VinnyB is offline
