Squeaky 01 LX HELP - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-03-2013, 08:24 PM   #1
iB Chunkyboy
Fan#: 105705
What I Drive: White 2001 Ford Focus LX 4DR Sedan
FF Reputation: 1 iB Chunkyboy Good Standing Member
Squeaky 01 LX HELP
Helllo,
I know this is a common issue with focus' as are some other things. i got my flex pipe fixed today. what a pain. but i've had a squeak going on. clearly its the belt. the reason i am posting this is because the past few days i hadn't driven it and it went away but once i got it going down the road and through the snow on the road and such it came back and when i got to my mechanic/friends today to put my flex pipe in he told me the reason it was squeaking was because there is a cover or gaurd missing from under the car. i cannot find one online. so maybe hes use to seeing these on other cars. but help?? is there an actual cover and i am not searching the right way or is there another problem weather it being the belt or pulley ? :] thanks
iB Chunkyboy is offline
Old 01-03-2013, 08:46 PM   #2
rjschi21
rjschi21's Avatar
Fan#: 96355
What I Drive: None
FF Reputation: 1 rjschi21 Good Standing Member
There may or may not be a splash shield missing. But the cause is probably due to a worn belt that starts squealing when it gets wet or on a cold startup. JMO.
rjschi21 is offline
Old 01-03-2013, 09:00 PM   #3
zpellicone
Fan#: 105007
What I Drive: 2001 Pitch Black ZTS
FF Reputation: 1 zpellicone Good Standing Member
I have an 01 zetec and when I brought the car in for a major repair they forgot to put the lower serp belt cover back on, it would squel in the rain going over puddles because it got wet. I got a new belt at the same time that I got a replacement cover so I can't say for sure that it was solely the cover or not. I would replace the belt as well s get a new lower belt cover. Dealerships should have them for less than 20 but I can't remember the part#
zpellicone is offline
Old 01-03-2013, 09:00 PM   #4
chris4479
Fan#: 93595
What I Drive: 2013 Hyundai
Points 25, Level 1
Points: 25, Level: 1 Points: 25, Level: 1 Points: 25, Level: 1
Level Up 49% Completed
FF Reputation: 1 chris4479 Good Standing Member
Check the last section of exhaust. My wagon was creaking last week,must be cold weather related. I've had an exhaust warm up and stop creaking. The catallic converter has 1 or 2 heatshields.cheers Chris//
chris4479 is offline
Old 01-03-2013, 09:08 PM   #5
iB Chunkyboy
Fan#: 105705
just had a complete exhaust put on manifold back so its not that, its def the belt but yes thank you all i'll look at replacing the belt and find a cover hopefully
Old 01-03-2013, 10:55 PM   #6
amc49
Fan#: 96610
Points 3,260, Level 35
Points: 3,260, Level: 35 Points: 3,260, Level: 35 Points: 3,260, Level: 35
Level Up 40% Completed
Forum Activity 3%
The cover prevents water hitting belt nearly so easy in heavy rain, the belt squeals then as they all will. Cover in and of itself does nothing to stop squeaking when everything dry though. When really cold, the cover often breaks when a big wad of water hits it as it is very cold, the plastic cracks easy then.
amc49 is offline
