Change steering wheel controls? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 01-03-2013, 02:01 PM   #1
turbosleepa
Fan#: 107143
What I Drive: 2012, Black focus titanium
FF Reputation: 1 turbosleepa Good Standing Member
do these just pry out? its driving me nuts that the volume controls are on the right side of the steering wheel. 2012 titanium. getting my laminate replaced on my steering wheel at ford this coming week and will be moving controls after.
turbosleepa is offline
Old 02-17-2013, 04:41 PM   #2
turbosleepa
Fan#: 107143
anyone have a steering wheel diagram?
Old 02-18-2013, 09:09 AM   #3
HoneyBadger
Fan#: 104860
What I Drive: 2012 Ford Focus SEL
FF Reputation: 1 HoneyBadger Good Standing Member
Be careful with the airbag as others have said about removing your steering wheel. Ford parts might have a diagram for you.
HoneyBadger is offline
Old 03-08-2013, 08:03 AM   #4
henryn
Fan#: 106006
What I Drive: 2001, black, Crown Victoria
FF Reputation: 1 henryn Good Standing Member
One needs to be careful with the airbag as others have said about removing your steering wheel as well.Though i would like a diagram for the same.
____________________
bmw floor mats
henryn is offline
Old 03-09-2013, 10:49 AM   #5
420Mac
420Mac's Avatar
Fan#: 110174
What I Drive: 2012 - Frozen White Zetec S
FF Reputation: 1 420Mac Good Standing Member
Hi,
!!!IMPORTANT WHEN REMOVING/WORKING AROUND AIRBAGS!!! Remove the negative battery terminal and wait a couple minutes. (Ford documentation says to wait one minute.)
Accessing Steering Wheel Controls -
1. Lower the steering column to its lowest setting.
2. Remove the Torx screw on the top of the upper steering column shroud.
3. Turn the wheel 90 and undo a clip for the upper steering column shroud.
4. Turn the wheel 180 the other way and undo the other clip.
5. Remove the upper steering column shroud and position it out of the way.
6. With the wheel still at 90, you will now be able to access a round hole on the back of the wheel. This provides access to a spring member than retains the airbag unit. Insert a flat blade screwdriver. You need to get between the spring member and its stop, so bias the screwdriver blade towards the steering column axis during insertion. When it's all the way in, twist it 90 to release the latch and pull on the airbag unit. This wasn't easy. You need a screwdriver with a small enough shaft to maneuver in the hole but a wide enough blade to disengage the latch when you twist it. I had to file one down.
7. Rotate the wheel 180 the other way and unlatch the other side.
8. Remove the airbag unit enough to access the connectors.
9. Disconnect the connector for the steering wheel controls.
10. Disconnect the two airbag connectors. You must pry up an orange locking mechanism to remove them, they look fragile at first, but they do come up.
Hope this helps.
420Mac is offline
