Advanced VCT CEL - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-03-2013, 10:06 AM   #1
02blacksvt
Fan#: 105081
What I Drive: black 02 svt
FF Reputation: 1 02blacksvt Good Standing Member
Advanced VCT CEL
I have this code in my car, can someone explain this to me and how can I fix this?
Well i started with nothing, and have most of it left.
02blacksvt is offline
Old 01-03-2013, 11:17 AM   #2
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,621, Level 31
Points: 2,621, Level: 31 Points: 2,621, Level: 31 Points: 2,621, Level: 31
Level Up 14% Completed
The SVT uses variable valve timing by advancing the cam.
If you are lucky, it might just be the cam position sensor gone bad.
elsolo is offline
Old 01-03-2013, 11:10 PM   #3
BC_ZX3
DTC P0606
BC_ZX3's Avatar
Fan#: 48751
Points 2,078, Level 27
Points: 2,078, Level: 27 Points: 2,078, Level: 27 Points: 2,078, Level: 27
Level Up 52% Completed
This DTC code?
P1381 - Variable Cam Timing Over-advanced (Bank 1)
The comprehensive component monitor (CCM) monitors the VCT position for an over-advanced camshaft timing. The test fails when the camshaft timing exceeds a maximum calibrated value or remains in an advanced position.
Causes:
Cam timing improperly set
No oil flow to the VCT piston chamber
Low oil pressure
VCT solenoid valve stuck closed
Camshaft advance mechanism binding (VCT unit)
P1381 DTC is a check of the VCT unit. Testing should not include electrical checks. Diagnostics and repair for the VCT unit are located in the Workshop Manual.
BC_ZX3 is offline
Old 01-03-2013, 11:21 PM   #4
02blacksvt
Fan#: 105081
So worst case I'm looking at a sensor for the cam?
Old 01-03-2013, 11:28 PM   #5
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Has the t-belt ever been changed? How many miles are on the car? If it's never been changed and it's got high mileage I'd be more concerned about that code, it could have jumped time or lost a tooth or something, or could be as simple as a sensor.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-04-2013, 01:04 AM   #6
elsolo
elsolo's Avatar
Fan#: 96835
You got that backwards.
The cheapest and easiest possible cause is the sensor.
Worst case is the camshaft VCT assy (that I believe ford has discontinued).
It sounds like you need to find somebody else to troubleshoot the problem.
elsolo is offline
Old 01-04-2013, 01:10 AM   #7
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
I'd check the t-belt asap IMO.
Moderator for
Technical Chat
Old 01-04-2013, 01:15 AM   #8
elsolo
elsolo's Avatar
Fan#: 96835
+ infinity
elsolo is offline
Old 01-04-2013, 06:52 AM   #9
waytocupok
Fan#: 108025
What I Drive: 2003 Pitch Black ZX3
FF Reputation: 1 waytocupok Good Standing Member
i can do ,it could have jumped time or lost a tooth or something, or could be as simple as a sensor.thanks
waytocupok is offline
Old 01-08-2013, 01:25 PM   #10
02blacksvt
Fan#: 105081
Well the car is at the dealer ship getting a good look over so wish it and my wallet luck
