#1 | ||||
Cylinder 1 Misfire? Help!
Alright. so some of you know. some of you don't. i have a Svt Ford Focus i bought to use the Engine and transmission etc to rip out and put in a kit car i'm about to get started on. how ever, i got the car for a steal. due to the fact that its needed some work. its not my daily driver. so i dont drive it much.. and today i started it up and went and got it washed so it wouldent look so sad out side. well the check engine light is on due to the fact that i have a Supercharger and no tune. yet. (waiting till i have some money for that) well i went to auto zone just to have them hook up to it and make sure it was not throwing up new codes. well it is. two.
i have noticed if i floor it, it bogs down. but then. Takes off! i thought this was due to a lack of a good tune which i plan on getting from tom. but i do not currently have the $ to toss out. well im starting to think i am having ignition coil problems/or wire problems to the coil. i have a new "Cylinder one misfire code" and a "lean bank one sensor" or two.. i cant remember now. Not sure if this makes a difference.. but as i said. i don't drive it as much as i should, when i started it up today. well. it didnt. battery was gone. so i got in my other car and tok the battery to auto zone. and i did get a new battery and put it in but i don't think that would be the issue. today's car wash turned out to be an eventful/expensive focus check up day
- Michael Price MEV Sonic 7 205+ HP JRSC |
Remove Advertisements |
Fan#: 1
#2 | ||||
Update, then off to bed for work.
Just took it on the highway for a quick drive after reading some topics on coil problems. i think i have a wire or coil problem. what do you guys think? i just left my place with it. driving around Normal or a little fast no problem, got on the on ramp to the highway, floored it. and it took off but was bogging when flooring it. as if i was pumping the gas. which i wasent. i had my foot all the way down. driving in 6th gear down the highway, it was fine. but would ocasinally randomly bog. got off the highway went under the over pass and got back on flooring it from a 2nd gear roll all the way to 75. No problem! took off like a supercharged focus. then off the highway home, bogged sometimes when i took off. was completely normal at others. it has a mind of its own it would seem. ill be busy at work till friday. just got off early today. but i dont think ill mess with it till saturday. what should i check for first? am i on the right trail assuming its coil related? i did get new spark plugs. i can change them sat too.
#3 | ||||
Yah pull the plugs off but you coukd have water down there if you washed under the hood so look before you pull them out. Also replace your wires and coil pack that is most likely your problem. So replace plugs, wires, and coil pack and you should be off to driving it.
#4 | ||||
Pulled out the old spark plugs. and cylinder one had a spark plug. With a crack in it! no idea how. they were in it when i got it a few months back. put in the new set of plugs. and wow... it is driving like a whole new car. feels likes its gained 80HP. takes off way better now. but after the fix. a new problem has occurred. (of course) now when i start the car, idles fine. but then after driving it hard and stopping. it idles around 2,000 to 3,000 RPM. it will slowly fall back down when stopped but only to about 1,900 RPM. this was not a problem before. idled great and quite around 1,200 or so. i'm about to unplug the battery to reset the ECU. but if that dosent fix it anyone know what els would cause this issue?
#5 | ||||
Never mind. Its perfect now! i reset the ECU and just took it back out. idles at 900 RPM now! when sitting. when i stop from a drive its about 1,000 to 1,100. but if i stay still long enough it will idle down to 900 and stay there. which i guess is normal. its quieter then it was before the fix too. at idle that is.
Thanks for the help!
| Thread Tools | |
| Display Modes | |
