dead miss - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-02-2013, 05:00 PM   #1
ynothd
ynothd's Avatar
Fan#: 107972
What I Drive: 2001, red, lx stock
FF Reputation: 1 ynothd Good Standing Member
dead miss
hi, thanks for reading and i hope someone can help me..... ok i had a 01 se that had a burned up wiring harness inside the car. the car ran just nothing in the car worked. car had been wrecked and someone did a bad repair job. so i bought a good body that had a split port motor and trans removed. pulled my split port motor and trans, put them in my good body now it is missing bad. bought a used coil and replaced no change, put in new plugs no change, put on another plug wire no change. the 2 plugs on the wiring harness that the motor wiring harness go to were cut off, so i cut mine off and wired them in. no problem but, 3 wires were solid white, 2 wires were brown with red stripe, and 2 were black with yellow stripe. there was no way to determine if the double wires were right or wrong when i hooked them up? please please help me im bout to lose my mind... lol...... i have to push a lil on the gas pedal to get it to even start but it did run good in the other car. im not an idiot have replaced many motors and never had this type of trouble. so i have double checked everything so im lost
ynothd is offline
Old 01-02-2013, 05:29 PM   #2
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
What I Drive: 77 F-250, 10 HHR, 08 Outlook
FF Reputation: 5 crazy_urn Good Standing Member
this diagram might help. it should be pretty similar to your 01:
http://www.scribd.com/doc/36638561/Ford-Focus-2002
not sure exactly what wires you are talking about, but if you can find them on here, perhaps it will give you a place to start.
Defending the reputation of the red-headed step-child of the focus world for far too long.
crazy_urn is offline
Old 01-03-2013, 02:49 PM   #3
ynothd
ynothd's Avatar
Fan#: 107972
ok it has A miss on cyl 1 and 4 , i put a used coil on no change, put a coil from a running car that i know is good no change, so are there different wiring harnesses for the focus spi motor? because i tried the computer from the car i took the motor out of and nothing worked, starter, dash lites, relays didnt click when key was turned on ect.ect.ect. someone please help me the two plugs im talking about are where the engine wiring harness hooks to the harness that goes thru the firewall to the computer at the back passenger side of under the hood so its like 1/2 the coil is not working or getting fire
ynothd is offline
Old 01-03-2013, 06:29 PM   #4
crazy_urn
Capt. Urn
crazy_urn's Avatar
Fan#: 1986
are you 100% sure the donor car was an SPI? do you know what year it was? if I recall correctly Ford changed some of the wiring after the 02 model year, but I don't remember what.
Old 01-05-2013, 12:19 AM   #5
ynothd
ynothd's Avatar
Fan#: 107972
yes both cars are 2001 split port engines focus lx
ynothd is offline
Old 01-05-2013, 12:49 AM   #6
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 140,700, Level 100
Points: 140,700, Level: 100 Points: 140,700, Level: 100 Points: 140,700, Level: 100
Level Up 0% Completed
Forum Activity 50%
Activity: 50% Activity: 50% Activity: 50%
FF Reputation: 50 sleepyboy Excellent Standing Member
Buy-Sell-Trade Rating: (11)
Have you checked the coil pack plug to make sure the wires aren't pulled out. It was a common problem on the early model's
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is offline
Old 01-05-2013, 09:49 AM   #7
ynothd
ynothd's Avatar
Fan#: 107972
what do you mean? pulled out of the plug or broken wires at the plug but the coating still good?
ynothd is offline
Old 01-05-2013, 09:45 PM   #8
ynothd
ynothd's Avatar
Fan#: 107972
can anyone give me a link to get what the wire numbers are on the computer plug for a 2001 focus lx ?????????
ynothd is offline
Old 01-05-2013, 11:26 PM   #9
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Forum Activity 50%
The plug itself, the part attached to the wiring harness. They can get pulled out causing a miss fire due to bad contact.
Moderator for
Technical Chat
Old 01-06-2013, 07:56 AM   #10
zetecDon
Where am I?
zetecDon's Avatar
Fan#: 62506
What I Drive: 02 ZX3, 02 MX-5
Points 13,157, Level 74
Points: 13,157, Level: 74 Points: 13,157, Level: 74 Points: 13,157, Level: 74
Level Up 77% Completed
Forum Activity 40%
Activity: 40% Activity: 40% Activity: 40%
FF Reputation: 29 zetecDon Great Standing Member
Buy-Sell-Trade Rating: (46)
Moved to "General Technical Chat". Instead of posting a duplicate thread, just bump this post up.
zetecDon is offline
