Cigar lighter and reverse lights not working...help please - Page 2 - Focus Fanatics
Old 01-01-2013, 10:39 PM   #11
calebstubstad
Chef Boyardee
calebstubstad's Avatar
Fan#: 103240
What I Drive: 2000 Atlantic Blue LX
FF Reputation: 4 calebstubstad Good Standing Member
my cig lighter was the fuse, easy $0.04 fix lol. as for the reverse lights, mine dont work either and im just taking it to the shop to get err fixed
Rally Revolution #43
[HOONIGAN]
Originally Posted by matmatician View Post
Not the bear the zoo deserves, but the bear the zoo needs.
calebstubstad is offline
Old 01-01-2013, 11:34 PM   #12
drummer829
Fan#: 71497
What I Drive: 2005 liq grey ST
FF Reputation: 1 drummer829 Good Standing Member
Originally Posted by elsolo View Post
How did that splice on the black ground wire get there?
i had a mechanic friend install the PIE aux interface thing for me and thats how he did it. I was charging my phone out of it no problem about a month ago, but now im not sure.
so im probably going to go out tomorow and buy a voltmeter, so how do i check the red/yellow wire and the ground wire?
drummer829 is offline
Old 01-01-2013, 11:37 PM   #13
drummer829
Fan#: 71497
i swapped out the fuse though and it was a no go ...
Old 01-02-2013, 06:30 AM   #14
mikeeshaq
Fan#: 72526
What I Drive: 2010 Transit Connect
FF Reputation: 15 mikeeshaq Great Standing Member
""""" so how do i check the red/yellow wire and the ground wire? """""
You COULD have a bad 'connection' in the cig lighter, meaning when a plug gets inserted it does not make good contact
Set meter to a scale that will read 12 Volts DC perhaps as a check you need to grab a 9 Volt battery and check that so at least you know how to use the voltmeter
ground the black meter lead onto a piece of the frame/body and scrape the surface a bit, now with the red meter lead poke around in back of the cig lighter and see if you don't get 12 Volts or something perhaps going right inside the cig lighter
If you get any indication then you have a bad cig lighter for what ever reason
ME? I have been chasing [invisible] electrons around for 35 years
mikeeshaq is offline
Old 01-02-2013, 01:12 PM   #15
drummer829
Fan#: 71497
Problem solved!!! I stole my girlfriends phone car charger, saw that it worked so I was confused. Found out the plug of the radar was a little worn, and for some reason it didn't fit in all the way. So I had to kind of play with it and almost like jam it in there. The phone charger fit like a glove with no issues.
