Old 01-01-2013, 08:40 AM   #1
dadi050
Fan#: 99657
What I Drive: 2001 ford focus black zts
FF Reputation: 1 dadi050 Good Standing Member
motor miss/hesitation
After I changed the valve cover gasket on my 2001 ZTS, I decided to clean the mass air sensor and throttle body with a mass air cleaner. Now while driving it will sputter and miss, but will continue to drive normally. This will only happen occasionally. This car has no mods its a daily driver. What did I do wrong?
dadi050 is offline
Fan#: 1
Old 01-01-2013, 10:57 AM   #2
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '03 Red EAP SVT, '04 Silver SVT
FF Reputation: 15 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
Moved to "General Technical Chat"
My Rides:
'13 Ingot Silver Escape Titanium AWD
'03 Infra Red EAP SVT, #1687, 1 of 101
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, FJ mod pic, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 01-01-2013, 11:17 AM   #3
cyfocus01
cyfocus01's Avatar
Fan#: 95790
What I Drive: 01 silver zts sedan
FF Reputation: 1 cyfocus01 Good Standing Member
OK, I'll bite first. So, there was no miss prior to gasket change and cleaning? Guessing 'no' by the post....
I'd just double check to make sure you didn't knock any vaccum lines loose, off, or crack them.
Also, double check all plug wires to make sure they 'clicked' when you put them back on.
Make sure all intake tubing is on correct, orientation, and tight.
Mine had an intermittent miss for a long time. Then the coil just instantly gave up on #2. new coil, no miss. Not saying that's it, that just happened to me. Good luck.
cyfocus01 is offline
Old 01-01-2013, 03:14 PM   #4
FocusedSlayer
has a screw loose
FocusedSlayer's Avatar
Fan#: 59042
What I Drive: 2007 CD Silver Sedan SE w/Sap
FF Reputation: 34 FocusedSlayer Great Standing Member
Buy-Sell-Trade Rating: (4)
Check and make sure have it going in the right direction. Check the wiring for a loose connection .
When you took it out and did the cleaning did you disconnect the negative battery cable? Anytime I'm messing with electrical components, that's the 1st thing I do. So when you get it back together let it idle normal or until the rpms drop. Then take it out for at least a 20 to 30 minute drive so your ECU can relearn the new parameters. And you should be good .
Posted via FF Mobile
FocusedSlayer is offline
