Rattle over bumps - front end? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-30-2012, 09:10 PM   #1
vegachicago
Fan#: 89988
What I Drive: 2012 Focus SEL Sterling Grey
Points 993, Level 16
Points: 993, Level: 16 Points: 993, Level: 16 Points: 993, Level: 16
Level Up 93% Completed
Level up: 93% Level up: 93% Level up: 93%
FF Reputation: 2 vegachicago Good Standing Member
Angry Rattle over bumps - front end?
I've got a front end rattle over small bumps or rough road. Seems to maybe be on the left driver side area. Not the transmission shifting or brakes since the noise is there with brakes applied or just coasting. This is not a clunk, just a metallic kind of rattle. I've checked under my car a number of times with a rubber mallet and cannot find anything. Not my Kysor shutters, or plastic rattle.
However, I find that if I raise the car and hit my axle, it almost makes the sound. Maybe a loose or worn carrier or axle bearing. It's been to the dealer 2 times with no luck. Does Not seem temperature sensitive either. Driving me nuts! I have around 8500 on the odometer. HELP
vegachicago is online now
Old 12-30-2012, 09:35 PM   #2
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,102, Level 92
Points: 22,102, Level: 92 Points: 22,102, Level: 92 Points: 22,102, Level: 92
Level Up 76% Completed
Level up: 76% Level up: 76% Level up: 76%
Forum Activity 13%
FF Reputation: 10 Twenty Great Standing Member
Sounds like mine. "Metallic rattle" is exactly how I've been describing it.
We have gone through mine once and found a few loose bolts which were then tightened. It's still there though.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 12-30-2012, 09:53 PM   #3
vegachicago
Fan#: 89988
Thanks Twenty. I AM NOT ALONE. I don't think it's dangerous, just annoying. Car works great otherwise. I don't complain about the trans. I came from driving a lot of manuals, to me its just a querky manual. I have drilled and inserted plastic screws on the whole front end plastic bumper and panels to eliminate that possibility. Still searching.
Old 12-30-2012, 10:03 PM   #4
revhigh
Fan#: 98516
What I Drive: 2012 Mazda 3 SkyActiv 6A Touring
FF Reputation: 1 revhigh Good Standing Member
http://www.focusfanatics.com/forum/showthread.php?t=267513
revhigh is offline
Old 12-30-2012, 10:10 PM   #5
vegachicago
Fan#: 89988
Revhigh, thanks for the link. I've read this front to back and it went the "CLUNK" in the tower thing and certain suspensions, none of which really pertains to the problem. Everyone in this thread talk about clunks. I've never had a clunk noise, just the small metallic rattle under 20 mph over small bumps. Around here there are lots of speed bumps and going over one does not produce the noise. Only little bumps and rough road. This is not the same problem in that thread, thanks anyway.
Old 12-31-2012, 10:44 AM   #6
Rememo
Rememo's Avatar
Fan#: 95534
What I Drive: Was 2012 Focus. Now 2013 Impreza.
FF Reputation: 3 Rememo Good Standing Member
Pound on your brake caliper. Maybe the pads are rattling around in there.
I seem to remember a post about someone having a dealer replace the calipers on their car.
Rememo is offline
Old 12-31-2012, 10:58 AM   #7
Bogey
Bogey's Avatar
Fan#: 104241
What I Drive: 2012, Ingot Silver SE
Points 1,696, Level 23
Points: 1,696, Level: 23 Points: 1,696, Level: 23 Points: 1,696, Level: 23
Level Up 96% Completed
FF Reputation: 1 Bogey Good Standing Member
Yeah i had the same as twenty done on my vehicle, but no success. Still there.
Bogey is offline
Old 12-31-2012, 01:53 PM   #8
vegachicago
Fan#: 89988
Rattle is there even when braking. Would the calipers or pads still make noise when applied? Can they rattle regardless of application of the brakes?
Old 12-31-2012, 02:47 PM   #9
Bogey
Bogey's Avatar
Fan#: 104241
They shouldnt, i have suspicion it might be the front windsheild cowl, when i tap it the sound is similar.
Bogey is offline
Old 12-31-2012, 05:30 PM   #10
vegachicago
Fan#: 89988
Bogey, you mean the plastic cowling at the exterior base of the windshield, just below the wipers?
