where should i buy a cv shaft - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 02-05-2013, 10:00 PM   #11
smallblockfever
smallblockfever's Avatar
Fan#: 95004
What I Drive: 2002 Sonic Blue SVT
Points 2,329, Level 29
Points: 2,329, Level: 29 Points: 2,329, Level: 29 Points: 2,329, Level: 29
Level Up 20% Completed
FF Reputation: 0 smallblockfever Newbie
So i bought one of the EMPI ones from Rock Auto
NOTE FOR EVERYONE:
In my search for the correct spline count, I soon found that it was an elusive number
SO here it is. For an SVT FOCUS the spline count is 34 inner/25 outer.
Note that the outer spline count is the same as any other focus due to similar knuckles.
In terms of the shaft itself, seems to work great, easy to install, good price, shipped fine, new shaft with no core charge, cost like $80, yadda yadda, rock auto is a great thing.
I'm still having other sounds though and they worry me.. I believe it is like bd8134 said, My dad and I over tightened the bolt and pressed the bearing, now we are having issues finding that sweet spot. In the mean time, i think the bearing is bad anyway and needs to have a new one pressed in.
smallblockfever is online now
Old 02-05-2013, 10:26 PM   #12
Magus2727
Magus2727's Avatar
Fan#: 62897
Points 8,695, Level 62
Points: 8,695, Level: 62 Points: 8,695, Level: 62 Points: 8,695, Level: 62
Level Up 82% Completed
Forum Activity 56%
Activity: 56% Activity: 56% Activity: 56%
Overtighten the bolt... what bolt? The "retaining" clasp on the passenger side CV shaft? the Nut you use gets tighten down to 170+ foot Lbs... It take a LOT of work to over-tighten the nut.
2001 ZX3 2.0L Zetec-
Hatch Nation #42
Magus2727 is offline
Old 02-06-2013, 08:19 AM   #13
SvviftSVT
ninja lurker status
SvviftSVT's Avatar
Fan#: 58277
Points 12,750, Level 73
Points: 12,750, Level: 73 Points: 12,750, Level: 73 Points: 12,750, Level: 73
Level Up 75% Completed
Forum Activity 78%
Activity: 78% Activity: 78% Activity: 78%
FF Reputation: 10 SvviftSVT Great Standing Member
Buy-Sell-Trade Rating: (6)
yeah, i still have some noises too.. i need a new end link.. and maybe strut top hats.
Track build has begun.
slow and steady.. but its going
SvviftSVT is online now
Old 02-06-2013, 10:59 AM   #14
trotskyite
Fan#: 95702
What I Drive: 2002 SVTF ZX3 Ebony Black #0849
FF Reputation: 1 trotskyite Good Standing Member
I replaced the passenger cv shaft in my 2002svtf last year. I had a squeal/chirp off and on and the outer boot was worn badly. In addition I had replaced the bearing, brake pads, rotor, strut, around the same time. Still didn't solve my occasional noise problem. Like the OP the sound would increase under corner and acceleration load. After a lot of trial and error later I found the problem to be the heater/AC cabin blower motor/fan. A worn bearing turned out to be the culprit, making a squealy chirpy noise when slight pressure was applied under load. I swapped it out for a new one from RockAuto for $55. Might not be your problem but just a thought as it is difficult to detect the difference from sound coming from there or the passenger wheel well when it the car needs to be in motion and under load to hear it. Good luck.
trotskyite is offline
Old 02-11-2013, 11:49 PM   #15
ukfan50
ukfan50's Avatar
Fan#: 91208
What I Drive: 2003 VW Golf GTI 20th AE #2485/4000
FF Reputation: 1 ukfan50 Good Standing Member
Originally Posted by trotskyite View Post
"problem to be the heater/AC cabin blower motor/fan. A worn bearing turned out to be the culprit, making a squealy chirpy noise when slight pressure was applied under load. I swapped it out for a new one from RockAuto for $55.."
Mine has made that same noise from the blower motor since I bought it, just when could though. Gonna replace it next time it's in for maitenance.
2003 BMP VW Golf GTI 20th AE #2845 of #4000 (Purchased 3/2014)
2002 Sonic Blue SVT Focus #1200 (Sold 2/2014)
2000 T-Red SVT Contour #1089 of #2150 (Sold 10/2011)
1998 BDP Subaru Impreza 2.5RS #1595 of #1695 (Sold 1/2010)
ukfan50 is offline
Old 02-12-2013, 05:00 PM   #16
vroom4
Fan#: 104480
What I Drive: 03 Blue fSVT
FF Reputation: 1 vroom4 Good Standing Member
Holy smokes I wonder if thats my problem. How did you eventually track it down? Mine also "rattles" in the cage every once in a while when I use the defrosters but I assumed the "clunking" noise was suspension.
vroom4 is offline
Old 02-13-2013, 12:36 AM   #17
ukfan50
ukfan50's Avatar
Fan#: 91208
Yeah I'm sure the noise your describing in suspemsion related.
The blower motors on the SVTF's suck!
ukfan50 is offline
Old 08-11-2013, 09:26 PM   #18
MustangCRZY302
MustangCRZY302's Avatar
Fan#: 72764
What I Drive: 2004 Sonic Blue SVT 3dr
Points 1,950, Level 26
Points: 1,950, Level: 26 Points: 1,950, Level: 26 Points: 1,950, Level: 26
Level Up 50% Completed
FF Reputation: 8 MustangCRZY302 Good Standing Member
Yea I just stared hearing a roaring at Highway speeds, I'm pretty sure its the carrier bearing on the Pass side CV shaft. Is that alone just replaceable? Or does the whole shaft have to be changed? CFM wants $360 for the shaft.... local parts stores want $60.... little confused....
SOLD - 2004 Sonic Blue SVT, 1,185 of 1,978, K&N Filter, Steeda Tri-Ax, Steeda Front Strut bar,Eibach Sway Bars, Fog-Light Mod, Yellow Fogs
1990 Mustang LX 5.0L, Project/race car Vortech'd, DSS Forged 331ci Stroker, 10psi
www.ajsracing.net
MustangCRZY302 is offline
Old 08-11-2013, 09:59 PM   #19
Magus2727
Magus2727's Avatar
Fan#: 62897
Forum Activity 56%
Likely the part store did not know you had an SVT. The SVT ones cost more and are harder to find. 60 is even cheap for a non SVT. I would say buy on rockauto.com however I don't think they "stock" the SVT ones.
Hatch Nation #42
Old 08-11-2013, 10:39 PM   #20
swansong
swansong's Avatar
Fan#: 83576
What I Drive: 2008 Saab 9-3 Aero SportCombi XWD
Points 2,308, Level 29
Points: 2,308, Level: 29 Points: 2,308, Level: 29 Points: 2,308, Level: 29
Level Up 6% Completed
Forum Activity 2%
FF Reputation: 12 swansong Great Standing Member
Buy-Sell-Trade Rating: (4)
I bought my axles at stockwiseauto.com, manufacturer is GSP, part numbers NCV11153 and NCV11154. Paid 110ish shipped for both sides. As far as I can tell these are the same parts that Advance Auto sells, the part numbers are the same anyway. Stockwise seems to be a newer company very similar to Rockauto, had no issues with my order.
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 92k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 84k, Ebony, Auto, Moon and Tune
swansong is online now
