L.E.D flex light install help - Focus Fanatics
Go Back   Focus Fanatics > Ford Focus First Generation > MK1 Focus
Old 12-29-2012, 11:07 AM   #1
Ckenny18
Ckenny18's Avatar
Fan#: 107441
What I Drive: 01 ZX3
FF Reputation: 1 Ckenny18 Good Standing Member
i got a set of the flex led strips from autozone and also got an on/off switch for them. i want to put them under dash so it light up the driver and passenger side by your feet. i was wondering if anyone had some ideas of where to connect the power to and and where to ground them to.
Ckenny18 is offline
Old 12-29-2012, 12:24 PM   #2
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
FF Reputation: 9 Kipp Good Standing Member
you can ground it to any metal surface pretty much. as far as power; the ignition harness with provide a good source. which wire depends on how you want them to work. for example whether you want them to be abloe to be turned on all the time or with accessory or only when the car is running.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 12-29-2012, 02:03 PM   #3
Ender92
Fan#: 90428
What I Drive: 04 pitch black lx sedan
FF Reputation: 1 Ender92 Good Standing Member
I have cold cathode tubes in all my footwells.What i did was get a(cant remember what it was called) an inline fuse holder??Basically its a fuse holder you plug into the fuse box and it has a power wire running from it.Run power to your switch then run power of switch to all your lights.
Ender92 is offline
Old 12-29-2012, 03:30 PM   #4
VinnyB
Fan#: 97705
What I Drive: '03 Screaming Yellow EAP
FF Reputation: 18 VinnyB Great Standing Member
You can ground them to any spot of bare metal. For my LED doorhandles, I have it grounded to the metal frame around the fuse box.
As for my power, I used a vampire tap in line with the switch that powers my headlights/instrument cluster.
I have a secondary switch that I installed in my center console so that they can be turned on/off independant of the headlights.
VinnyB is offline
Old 12-29-2012, 07:51 PM   #5
Sevenev
Fan#: 106511
What I Drive: 2007 Pitch Black ZX3
FF Reputation: 1 Sevenev Good Standing Member
I found the wire for the domelight in the bundle of wires under the driver side door sill and spliced into it. With that I don't need a switch. They turn on with the dome light when the door opens or when the engine turns off.
Sevenev is offline
