coolant leak - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-28-2012, 02:29 PM   #1
mrdivito
Fan#: 107497
What I Drive: 2003 comp orange svt
FF Reputation: 1 mrdivito Good Standing Member
coolant leak
So today i decided to look for my coolant leak, every morning i see a spot of coolant from being parked over night so i went under the car to see. im not sure what this is or what would need to be replaced but this is where its leaking from.
mrdivito is offline
Old 12-28-2012, 02:56 PM   #2
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
What I Drive: '14 TB ST3, '04 Silver SVT
Points 15,057, Level 79
Points: 15,057, Level: 79 Points: 15,057, Level: 79 Points: 15,057, Level: 79
Level Up 42% Completed
Forum Activity 3%
FF Reputation: 17 BLRich1 Great Standing Member
Buy-Sell-Trade Rating: (6)
its a "freeze plug" on the bottom of the thermostat housing. More than likely you just need a new O Ring. Do a search for Viton o ring on here and you will find the size.
My Rides:
'14 Tuxedo Black ST3
'13 Ingot Silver Escape Titanium AWD
'04 CD Silver SVT, #877, 1 of 135 May 2011 ROTM, FF11: Best Display, Best of Show; AFN12: Best SVT, Best Audio, Finest Five, Carlisle Nifty Fifty
BLRich1 is offline
Old 12-28-2012, 02:58 PM   #3
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
Forum Activity 3%
Here is the part number you need:
part number 9464K543 - description: Viton O-Ring AS568A dash number 203, packs of 25 (Same as 9464K342)
My Rides:
BLRich1 is offline
Old 01-02-2013, 10:53 AM   #4
mrdivito
Fan#: 107497
Alright i found the part, how would i go about replacing it? as in how does it come off to get to the o-ring?
mrdivito is offline
Old 01-02-2013, 11:01 AM   #5
BLRich1
Nope, Chuck Testa
BLRich1's Avatar
Fan#: 22758
Forum Activity 3%
Pull the clip/pin out. In your second pic, you can see the top of it. I'm not sure what its called, but its like a reverse cotter pin, it goes around the outside edges of the freeze plug. Once the pin is out, pull the plug out. Beware, coolant will be coming out so either bleed some off or have a bucket ready.
once the old one is out, put the new gasket on and put the plug back in. It may take some "motivating". once its in, pop the pin back in.
My Rides:
BLRich1 is offline
Old 01-02-2013, 02:13 PM   #6
Hempster
Hempster's Avatar
Fan#: 29310
What I Drive: 2014 Tuxedo Black Focus ST3
Points 739, Level 14
Points: 739, Level: 14 Points: 739, Level: 14 Points: 739, Level: 14
Level Up 39% Completed
FF Reputation: 3 Hempster Good Standing Member
I suggest you pull the housing and inspect the main ring that seals the housing to the block and make sure there is no oil migrating down the block. Oil swells the rubber and will eventually break the housing. I would also suggest changing the sensor o-ring, on top, to viton while you are at it. I would get about two years before I would get a leak with the oem rubber o-rings, but it's been over 3 since I replaced them with the viton type.
It's also a great opertunity to do a flush.
good luck....
Tuxedo Black 2014 Focus ST3
CD Silver 02 SVTF, #1336 - R.I.P.
"Brace for the G's, and fast heel-toe work!"- Hunter S. Thompson
Hempster is offline
Old 01-04-2013, 07:37 AM   #7
*Z3R0*
*Z3R0*'s Avatar
Fan#: 101194
What I Drive: 2004 MoonDust Silver Focus ST170
FF Reputation: 1 *Z3R0* Good Standing Member
Mine was also leaking the exact same spot, but I opt on changing the whole thermostat housing. Wasnt too expensive. My one friend's was also leaking and they changed the o-ring but kept on leaking, rather change the whole housing then you know its done
2004 Ford Focus ST170 MoonDust Silver Newskool
1987 Ford Sierra 3.0 GLX Black Metallic Pearl Oldskool
1974 VW Beetle Metallic Purple Rocking a Roofrack
*Z3R0* is offline
