2000 Focus Vents Stuck? - Focus Fanatics
Old 12-27-2012, 04:20 PM   #1
2000FFocusLX
Fan#: 99932
What I Drive: 2000 Black LX
FF Reputation: 1 2000FFocusLX Good Standing Member
The vents in my 2000 Focus LX are stuck on defrost. Still works on all 4 speeds and the heat works. By stuck I mean stuck. It WILL NOT switch out of defrost. I broke one switch trying, then went down to where to switch connects and tried down there too. No movement whatsoever.
Any idea what is wrong with it and how to fix it?
The switch is the vent selector: defrost, feet-face, feet, face. It is NOT the switch itself. PLEASE ANYONE WITH KNOWLEDGE HELP. I've been dealing with this for well over a year now and Really need this fixed for winter, I am moving to north dakota in less than a month and cannot afford to pay a dealership $800 for a small fix like this (I know dealerships Especially Ford really try to screw you with parts and labor).
Last edited by 2000FFocusLX; 12-27-2012 at 06:49 PM. Reason: I really need help with this problem, can provide a slightly more in-depth description.
2000FFocusLX is offline
Old 12-27-2012, 08:29 PM   #2
MEJY1988
Fan#: 101883
What I Drive: 2006 Burgandy ZX5
FF Reputation: 3 MEJY1988 Good Standing Member
I am no expert but, you may want to check out the following:
Does your vent selector stick? Have you broken the cables? Read on,
Hope it helps. Good luck.
I was a Shade Tree Mechanic, but had to cut down the Shade Tree to make room for the garage. Does this make me a Mechanic now?
MEJY1988 is offline
Old 12-28-2012, 01:21 AM   #3
2000FFocusLX
Fan#: 99932
Thanks for the reply! That does help out, but he didn't completely specify. It might be a vacuum leak I'm thinking.. because it is stuck in defrost.. I'm going to pull the glove box off tomorrow and see if I can find out if anything is blocking the vents, I hope so. Because I have no idea what I'm doing. Anyway, more help would be appreciated.
Old 12-28-2012, 05:07 AM   #4
whynotthinkwhynot
Captain TMI
whynotthinkwhynot's Avatar
Fan#: 18416
What I Drive: 05 ZXW; 02 Windstar; 13 C-Max SEL
FF Reputation: 270 whynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Memberwhynotthinkwhynot Outstanding Standing Member
Focus vent selectors are controlled by a cable, not vacuum. Be thankful, vacuum actuated controls are not fun to diagnose problems on.
Be eclectic.
You're special aren't you.
whynotthinkwhynot is offline
Old 12-28-2012, 07:31 AM   #5
rsnow
Fan#: 105358
What I Drive: 2002 pitch black svt
FF Reputation: 1 rsnow Good Standing Member
yes they are cables, check the selector cable, may be stuck, look where it attachs to the blen door box
rsnow is offline
Old 12-28-2012, 02:35 PM   #6
2000FFocusLX
Fan#: 99932
I already snapped the cables, when I was replacing them I tried manually changing it with the selector down by the blend door box on the outside, and the thing will not turn at all... The cables are not the problem. I already snapped and replaced them. The problem is whatever is behend the switch Which I have no idea how to check or anything.
Old 12-28-2012, 02:54 PM   #7
mark315
Fan#: 107809
What I Drive: 2007 green zx4
FF Reputation: 1 mark315 Good Standing Member
I have the same problem with my '07. I replaced the Bowden cable. The upper blend "lever" that is part of the heater box works fine. However the lower blend lever is stuck. Does anyone have steps to access the heater box so I can remove the obstruction? I'm not sure blowing air in through the blower motor opening will work as it seems pretty far away from the problem area.
Thanks
mark315 is offline
Old 12-28-2012, 03:07 PM   #8
2000FFocusLX
Fan#: 99932
Thanks
Is yours stuck on defrost also?
Old 12-28-2012, 03:23 PM   #9
mark315
Fan#: 107809
I can get 2 positions. Defrost and vent. No heat at floor, no defrost/heat mix.
mark315 is offline
Old 12-28-2012, 04:14 PM   #10
2000FFocusLX
Fan#: 99932
Hm. That's how mine was before it got stuck on defrost. I'm betting something is blocking the vents from changing
