The all-new Volvo V40 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Discussions > Ford Focus & General Car Chat
Old 12-27-2012, 08:49 AM   #1
FFTeam
Administrator
Fan#: 41389
Points 45,037, Level 100
Points: 45,037, Level: 100 Points: 45,037, Level: 100 Points: 45,037, Level: 100
Level Up 0% Completed
FF Reputation: 4 FFTeam Good Standing Member
The all-new Volvo V40 boasts class-leading driving dynamics thanks to focused attention to a number of vital areas.
The chassis has been designed to offer the agile, connected experience that creates true driving pleasure.
The engine range spans everything from Volvo Car Corporation's first diesel with CO2 emissions of just 94 g/km to the turbocharged T5 petrol engine with 254 hp and acceleration from 0 to 100 km/h in 6.1 seconds.
All engine versions have start-stop and braking energy regeneration, no matter whether they are fitted with a manual or automatic gearbox.
Dynamic chassis standard
The all-new Volvo V40 has two different chassis setups:
-The Dynamic chassis is standard. The rigid body and low centre of gravity promote an alert, quick-responding character that focuses on the driving experience, yet without compromising ride comfort.
The front McPherson struts have the same 25 mm piston rods as the Volvo S60. The stiffness enables the structure to absorb lateral loads better.
At the rear the V40 has monotube dampers, featuring compression and return damping via the same valve. This gives shorter, faster fluid flow, which in turn means that the damper responds more quickly.
The Sport chassis is lowered 10 mm compared with the Dynamic chassis. Springs and shock absorbers have a firmer setting, resulting in responsive driving pleasure with full control.
Steering with precise response
The steering column's thick tubing and stiff insulator increase torsional rigidity. This also contributes to the enhanced feeling of direct contact with the wheels and the road.
The Electrical Power Assist Steering (EPAS) uses an electrical motor to support the steering rack and the driver can choose between three levels of power assistance:
In Low mode the system provides a high degree of power support, making manoeuvring easier. Medium mode has somewhat lower power support to offer more road response at higher speeds. High mode is the ultimate setting for the enthusiastic driver, contributing to the car's dynamic character.
Electrical Power Assist Steering enables integration of safety and driver support functions that involve the steering, such as Lane Keeping Aid and Park Assist Pilot.
Roll angle sensor enhances stability
The Dynamic Stability and Traction Control (DSTC) system in the all-new Volvo V40 includes several sophisticated features that offer a unique blend of driving pleasure and safety.
Advanced Stability Control uses a roll angle sensor that makes it possible to identify any skidding tendency at a very early stage. This means that the stability control system can step in earlier and with greater precision. Advanced Stability Control is a great asset in dynamic driving involving considerable lateral forces, improving handling and rapid avoidance manoeuvres.
Engine Drag Control prevents the wheels from locking during engine braking on a slippery surface.
If the car is equipped with a towing hook, Trailer Stability Assist helps dampen the snaking action that may occur when towing a trailer or caravan. The car is stabilised by braking one or more wheels and by reducing torque.
Corner Traction Control - tightening the corners
Corner Traction Control is a new feature that uses torque vectoring so the car corners even more smoothly. The car's inner driven wheel is braked, causing more power to be transmitted to the outer driven wheel. This allows the driver to corner more tightly while reducing any tendency to understeer.
This system makes it easier to smoothly maintain the desired line on winding roads, in roundabouts and on wet surfaces. Corner Traction Control is a huge asset when exiting from a small side road to merge swiftly with faster highway traffic.
Range of eager petrol engines
The five-cylinder 2.5-litre turbocharged T5 engine has a power output of 254 hp and 400 Nm of torque, including 40 Nm overboost delivered during acceleration. To achieve low fuel consumption and CO2 emissions, internal friction has been reduced.
The T5 comes with automatic transmission and acceleration from 0-100 km/h to 6.1 seconds. Fuel consumption is 7.9 l/100 km (EU Combined).
The T5 is also available in a 2.0-litre version with 213 hp and 300 Nm of torque. The mid-range offer includes two versions of a 1.6-litre GTDi engine: T4 with 180 horsepower and T3 with 150 horsepower.
The 180 hp engine offers maximum torque of 270 Nm, including 30 Nm overboost. This gives excellent lugging ability throughout the speed range. The torque curve is relatively gentle, resulting in a particularly comfortable driving experience.
The 150 horsepower T3 engine offers 270 Nm of torque, including 30 Nm overboost. Volvo's engine experts have managed to bring fuel consumption down to 5.3 l/100 km in the V40. This corresponds to CO2 emissions of 124 g/km.
A 2.0-litre five-cylinder T4 engine with 180 hp and 300 Nm of torque is available on certain markets.
Smooth Powershift transmission
The T5 version comes with a six-speed automatic gearbox, while the T4 is available in combination with the automatic six-speed Powershift transmission or a six-speed manual gearbox. The T3 comes with a manual gearbox.
Powershift operates in principle as two parallel manual gearboxes with separate clutches, a system that provides quick and fuel-saving gear changes.
Fuel-efficient diesels
The five-cylinder 2.0-litre D4 turbodiesel has been optimised for fuel-efficient driving pleasure. The piezoelectric fuel valves keep fuel consumption to a minimum thanks to exceptionally fast and precise injection pulses under high pressure. This results in efficient combustion. In order to give the car better driving properties, the turbocharger has been fine-tuned for high torque from low revs.
This engine delivers 177 hp and has torque of 400 Nm across a wide rpm range. Acceleration from 0-100 km/h takes 8.3 seconds with the automatic gearbox (8.6 sec with manual). Fuel consumption and CO2 emissions are 4.3 l/100 km (114 g/km) with a manual gearbox and 5.2 l/100 km (136 g/km) with the automatic (EU Combined).
In addition there is the 2.0-litre D3 producing 150 hp and 350 Nm of torque.
Both turbodiesels are available with a six-speed automatic transmission or six-speed manual gearbox.
D2 version with CO2 emissions of 94 g/km
The D2 version of the Volvo V40 comes with CO2 emissions as low as 94 g/km - corresponding to fuel consumption of just 3.6 l/100 km. The 1.6-litre diesel engine has 115 hp and 270 Nm of torque. The D2 engine is combined with a six-speed manual gearbox and start/stop function.
Other details such as smooth underbody panels also contribute to low fuel consumption and low emissions.
The 1.6-litre diesel engine can also be mated to the six-speed Powershift gearbox.
Engine range:
Petrol engines Displacement Configuration Output Torque
T5 2.5 5-cyl in-line 254 hp 360 Nm + 40 Nm overboost
T5 2.0 5-cyl in-line 213 hp 300 Nm
T4 1.6 4-cyl in-line 180 hp 240 Nm + 30 Nm overboost
T4 2.0 5-cyl in-line 180 hp 300 Nm
T3 1.6 4-cyl in-line 150 hp 240 Nm + 30 Nm overboost
Diesel engines Displacement Configuration Output Torque
D4 2.0 5-cyl in-line 177 hp 400 Nm
D3 2.0 5-cyl in-line 150 hp 350 Nm
D2 1.6 4-cyl in-line 115 hp 270 Nm
Volvo V40 R-Design
Account Administration
FocusFanatics.com
FFTeam is offline
Old 12-27-2012, 09:02 AM   #2
rambleon84
So mote be it
rambleon84's Avatar
Fan#: 51521
Points 7,906, Level 59
Points: 7,906, Level: 59 Points: 7,906, Level: 59 Points: 7,906, Level: 59
Level Up 78% Completed
Forum Activity 38%
Activity: 38% Activity: 38% Activity: 38%
FF Reputation: 24 rambleon84 Great Standing Member
Buy-Sell-Trade Rating: (15)
Not a bad looking hatch, are these still made by the Swedes? Curious to see what the Polestar version will put out in the 2.5t (assuming they will have a tune for it.)
rambleon84 is offline
Old 12-27-2012, 11:40 AM   #3
Malibooya
Quarter Tank Racer
Malibooya's Avatar
Fan#: 68054
What I Drive: 2003 Pitch Black ZX3
Points 3,398, Level 36
Points: 3,398, Level: 36 Points: 3,398, Level: 36 Points: 3,398, Level: 36
Level Up 32% Completed
FF Reputation: 7 Malibooya Good Standing Member
Can we have the 6 speed with the 2.0 diesel? Would be a great entry to the US market if Volvo can hit 45MPG US.
Originally Posted by LouBomb
Omaha is worthless besides the World Series of College Baseball and horny white girls that for some odd reason find me attractive.
Malibooya is offline
Old 12-27-2012, 11:42 AM   #4
lyonsroar
Guest
Fan#: 63166
What I Drive: 2009 Volkswagen GTI
FF Reputation: 31 lyonsroar Great Standing Member
That's no hatch, that's a WAGON! A real WAGON!
I really wish I'd have gotten a 1st gen v40 instead of the s40 for my first car...
YouTube Video
lyonsroar is offline
Old 12-27-2012, 11:45 AM   #5
mac.mogul
mac.mogul's Avatar
Fan#: 90409
What I Drive: 2011 Sterling Grey SES Sedan
Points 3,995, Level 40
Points: 3,995, Level: 40 Points: 3,995, Level: 40 Points: 3,995, Level: 40
Level Up 23% Completed
FF Reputation: 14 mac.mogul Great Standing Member
Volvos now are very attractive, but that grille ruins it. The grille is the only thing that lets you know it's a Volvo anyway. It could be a Hyundai at a glance...
2011 SES 5spd #006 >> SR #213
What other people think of me is none of my business.
mac.mogul is offline
Old 12-27-2012, 04:04 PM   #6
elsolo
elsolo's Avatar
Fan#: 96835
Points 2,622, Level 31
Points: 2,622, Level: 31 Points: 2,622, Level: 31 Points: 2,622, Level: 31
Level Up 15% Completed
Forum Activity 2%
I don't like their departure from the more traditional Volvo wagon styling.
The 850 wagon was a great looker, they kept it up through the v70 model until they ruined it with the pointy nose in 2001, but the rest looked good. It got better again in 2010. I dig volvo fwd wagons, but only the 93-98, and 2010+
The v40 never looked all that much Volvo, it looked like an early 90's Accord Wagon everywhere but the front fenders and grill.
The v50 was a good looking Volvo, a good combination of traditional Volvo wagon looks but a little less brick-like and modernized.
This new v40 looks just like every other 5 dr hatch out there now, these things are getting to be like nascar, the bodies are the same and the only way to tell is by reading the grill badge.
elsolo is offline
Old 12-27-2012, 04:31 PM   #7
Kipp
FocusFest Event Team
Kipp's Avatar
Fan#: 31300
What I Drive: 2013 F150 4x4 5.0, 2014 HD 883 Iron
Points 4,517, Level 42
Points: 4,517, Level: 42 Points: 4,517, Level: 42 Points: 4,517, Level: 42
Level Up 84% Completed
FF Reputation: 9 Kipp Good Standing Member
I like it. Kinda looks like another car that came out recently.
2013 F150 4x4 SCrew XLT 5.0L
Midwest Crew #22
Official FocusFest Event Planner
Kipp is offline
Old 12-27-2012, 04:42 PM   #8
Supernaut
Fan#: 85958
What I Drive: '99 Kawasaki Ninja EX500
FF Reputation: 1 Supernaut Good Standing Member
I really like this car but I agree with the last couple posts on styling.
What I would like to see is some retro modern cars come out. And not cheesy ones like the Pt Cruiser and HHR. Some retro American cars, A retro 60's styled Volvo would be sweet... or VW... How about a pickup truck that's offered in a modern form or a (tastefully) 50's inspired style but they're both mechanically the same for make production feasible. There are a lot of possibilities out there.
I think the idea has so far been best accomplished by the Mustang of the last several years. Mini and Fiat 500 aren't bad shots either.
Maybe its not a new idea but it would break up a lot of the monotony on the road. I'm no design artist but I can't very well see a new never before done direction in auto styling.
Supernaut is offline
Old 12-27-2012, 04:46 PM   #9
Holden
Holden's Avatar
Fan#: 90783
What I Drive: 2004 SVTF
Points 251, Level 5
Points: 251, Level: 5 Points: 251, Level: 5 Points: 251, Level: 5
Level Up 2% Completed
FF Reputation: 1 Holden Good Standing Member
Love it; but I thought the US wasn't getting it?
Holden is offline
Old 12-27-2012, 04:47 PM   #10
mac.mogul
mac.mogul's Avatar
Fan#: 90409
I'm sure the problem Volvo has with using retro/modern designs is that their retro styles are not exactly iconic.... Mini, Fiat, Mustang, Thunderbird.... they all come from iconic styles and bringing them into the modern era of styling makes a lot of sense...
Bringing an old Volvo into the modern era isn't logical. Only the purists (all ten of them) would look at it and say "that's a Volvo" while everyone else would be scratching their heads.
