Install/Review: RedlineGoods Mk3 Shift Boot - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Go Back   Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum > Ford Focus Third Generation > MK3 Interior Mods & Upgrades
MK3 Interior Mods & Upgrades The place to chat about performance gauges, shifter knobs, custom interior paint, car seats or any interior upgrades for the 2012 Focus.
Old 12-26-2012, 06:59 PM   #1
Twenty
Sonic's Mk3 Crew #17
Twenty's Avatar
Fan#: 90312
What I Drive: 2012 YB SE sedan w/ ST exterior
Points 22,076, Level 92
Points: 22,076, Level: 92 Points: 22,076, Level: 92 Points: 22,076, Level: 92
Level Up 73% Completed
Level up: 73% Level up: 73% Level up: 73%
Forum Activity 12%
FF Reputation: 10 Twenty Great Standing Member
This is something I've wanted to address for a while, but only finally had the chance to.
Having the Sport seats in my Focus, there's plenty of nice silver accent stitching in the interior. It runs all over those seats but doesn't continue to the rest of the cabin. I wanted to tie in other parts of the interior by using matching stitching, and the shift boot was one of those parts. I was prepared to restitch the original but then I saw that Redlinegoods had a pattern for the Mk3s so I placed an order.
I also took this as an opportunity to change to a different material for the boot. Since some Ford models like the new Taurus SHO have Alcantara accents, that's what I opted for; genuine black Alcantara.
It was a bit of a gamble to specify the stitching colour with only a photo on their website to estimate a match, but I feel it worked out pretty well.
Since it's now Christmas break I had the time to take the old boot out and switch over to the new one.
Yesterday I started on the process of installing the new shift boot. Overall it was fairly straight-forward, and I am very happy with the finished product.
It started by once again removing the stock boot and silver trim from the car and separating the two.
The OEM boot is held in with glue around the plastic base. I used a hobby knife to carefully cut them apart, trying to keep the original leather boot more or less intact. It came out just fine with the only cut sections being the small square contact points where it was glued.
Alignment of the new boot was critical. With the obvious silver stitching, I did my best to ensure it'd line up like stock so that the stitching would be in each of the four corners of the silver trim. It would be clear if it wasn't aligned properly.
It took some delicate repositioning but I got it as close as I could. The new boot wasn't exactly the same dimensions as the stock one, but I was able to position the four coners fairly well around the plastic base.
Looking at the plastic base, you'll want the stitching to line up, centered, within the indented section at each corner.
Some binder clips were used to hold the boot as I adjusted its fitment, continually placing the silver trim back on top to double check.
When I was happy I then used a high-strength modeling adhesive and worked my way around the boot, applying it to one section at a time while leaving the rest clamped to avoid the boot becoming misaligned. When I was done I let it cure overnight.
Today I removed the clips, did some minor trimming of the boot to clear some of the tabs on the backside of the silver trim, and reassembled it (Bad picture, I apologize. It was the only one I had).
I then went into the garage and tested it. I found that the new boot was actually tall enough to sit against my shift knob while maintaining enough slack to go through all of the gears. This was not the case with the OEM leather piece.
However, I felt I wanted it tied down a bit lower as the original had been. I fastened a ziptie around the end and set it to the height I wanted. With the trim clipped back in place and the shift knob reattached, it was in and I'm happy.
As I had mentioned I had to take a bit of a gamble in specifying the stitching's colour, as I only had an online photo to work from. It worked out and I was able to get a very good match for the seats.
SUMMARY
Quality: Very good. Beautiful material, even stitching.
Fitment: Snug but good. Almost sized exactly like the original.
Installation: Needs patience but is straight-forward. If you have that and some basic hobby supplies you're set.
Overall: Very happy. This is something I've wanted for a long time and RedlineGoods came to the rescue.
officialTHREETWENTY
2012 YB Focus SE Sedan [featured in Performance Ford, Sept '14]
1992 BW Grand Prix SE Sedan [restomod project]
SR#74/SMk3C#17/YBOC#03
Bill M.
Twenty is offline
Old 12-26-2012, 07:16 PM   #2
miuzi05
miuzi05's Avatar
Fan#: 106045
What I Drive: 2013 Race Red SE Sedan 5MT
FF Reputation: 1 miuzi05 Good Standing Member
That looks awesome. I love the choice of Alcantara.
miuzi05 is offline
Old 12-26-2012, 07:38 PM   #3
Deftmetal
Moderator
Deftmetal's Avatar
Fan#: 105884
What I Drive: 2014 Mazda 3
Points 6,045, Level 50
Points: 6,045, Level: 50 Points: 6,045, Level: 50 Points: 6,045, Level: 50
Level Up 48% Completed
Level up: 48% Level up: 48% Level up: 48%
Forum Activity 4%
FF Reputation: 9 Deftmetal Good Standing Member
Looks great. Do they offer many materials?
Deftmetal is offline
Old 12-26-2012, 07:41 PM   #4
SonicZXIII
SonicZXIII's Avatar
Fan#: 90927
What I Drive: 2005 Sonic Blue ZX3
FF Reputation: 1 SonicZXIII Good Standing Member
very nice
FO-FO FO SURE
Rolling in a 2005 ZX3 Roush SVT combo
"When a man opens a car door for his wife, it's either a new car or a new GF.
SonicZXIII is offline
Old 12-26-2012, 09:52 PM   #5
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 12%
Thank you! Inspired by the new Taurus SHO's available Alcantara accents.
Tons. It can take a while to pick from their selection.
Originally Posted by SonicZXIII View Post
very nice
Thanks! It was exactly what I wanted.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 12-26-2012, 10:04 PM   #6
mainest
mainest's Avatar
Fan#: 60163
What I Drive: '04 Red Euro SVT
Points 1,855, Level 25
Points: 1,855, Level: 25 Points: 1,855, Level: 25 Points: 1,855, Level: 25
Level Up 55% Completed
Forum Activity 3%
FF Reputation: 8 mainest Good Standing Member
Buy-Sell-Trade Rating: (12)
Excellent choice of material, and great installation!
In my experience, redlinegoods.com makes top quality products, and has top notch customer service.
mainest is offline
Old 12-26-2012, 10:34 PM   #7
swansong
swansong's Avatar
Fan#: 83576
What I Drive: 2008 Saab 9-3 Aero SportCombi XWD
Points 2,275, Level 28
Points: 2,275, Level: 28 Points: 2,275, Level: 28 Points: 2,275, Level: 28
Level Up 84% Completed
FF Reputation: 12 swansong Great Standing Member
Buy-Sell-Trade Rating: (4)
Very nice! Since you took the time to do a install and writeup review, did they give you the boot for free? I know they offer something like that for "new" products.
Mine: 2008 Saab 9-3 Aero SportCombi XWD: 92k, Black, Manual, JZW Stage 1. 320hp/400tq.
Gone: 2002 SVT, #1654
Hers: 2010 Focus SES: 84k, Ebony, Auto, Moon and Tune
swansong is online now
Old 12-26-2012, 11:05 PM   #8
Twenty
Twenty's Avatar
Fan#: 90312
Forum Activity 12%
There was a minor bit of confusion I will report, only because I was so fast to order that even they didn't yet know their Mk3 prototype fit.
I had known of them for a while but until the Focus I didn't have a car they could make a boot for. I'm glad I finally got to buy from them.
I should be receiving some money back for it. Definitely a fair trade in my opinion.
officialTHREETWENTY
Bill M.
Twenty is offline
Old 03-27-2014, 05:21 PM   #9
2013Tuxe
2013Tuxe's Avatar
Fan#: 120068
What I Drive: 2013 Tuxedo Black Titanium
Points 795, Level 14
Points: 795, Level: 14 Points: 795, Level: 14 Points: 795, Level: 14
Level Up 95% Completed
Level up: 95% Level up: 95% Level up: 95%
FF Reputation: 1 2013Tuxe Good Standing Member
I ordered mine yesterday. Black leather with red stitching and racing stipe!
2013 Tuxedo Black Titanium Sedan | Sedan Rev #305
e-Focus RMM, drop-in K&N Air Filter, snorkel delete, AM Satin Silver Shift Knob with Redline Goods shift boot, RDC Zetec S Grill, and Husky Liners Weatherbeater Floor Liners for the kiddo!
2013Tuxe is offline
Old 04-07-2014, 09:39 PM   #10
2013Tuxe
2013Tuxe's Avatar
Fan#: 120068
Got it in today! Now to find the time, and patience, to install it...
2013Tuxe is offline
