Ok Listen up.... - Page 4 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-17-2013, 12:45 AM   #31
amc49
Fan#: 96610
Points 3,362, Level 36
Points: 3,362, Level: 36 Points: 3,362, Level: 36 Points: 3,362, Level: 36
Level Up 8% Completed
Forum Activity 39%
Activity: 39% Activity: 39% Activity: 39%
I don't think it's sensor, although they commonly go bad.
Have you POSITIVELY checked or changed the PCV hose where it attaches at the BACK BOTTOM of the intake?? Don't say you've 'checked it' if you haven't crawled under the car, just screwing yourself. Look at the last 3-4 inches before the hose goes into the intake and FEEL it, if like bubblegum you need new hose. The most common vacuum leak on these cars.
To check the brake booster check valve. Start motor up, let it warm at idle. Shut motor off and then within 5 seconds step on brake pedal ONE TIME, see if you have soft pedal then. Bend close and listen for a short soft hissing sound too. If check valve is working, you will get soft pedal up to 2 or 3 pushes and the hiss those 2-3 times, then it will get hard and the hiss stops. If hard the very first time you push it and no hiss then check valve or booster or hose is bad.
amc49 is offline
Old 01-17-2013, 11:35 AM   #32
Incognito27
Incognito27's Avatar
Fan#: 34939
What I Drive: 2003 Ford Focus ZX5 Premium - White
FF Reputation: 3 Incognito27 Good Standing Member
i have checked the PCV hose , However it was just by feel as its a pain to get at. come spring i will have another look at it. The Booster check valve i will try what you mentioned and go from there.
Thanks
PS today is a cold day so i am gonna see if the car bogs today.
Hatch Nation # 111
Incognito27 is offline
Old 01-17-2013, 05:12 PM   #33
Incognito27
Fan#: 34939
so it seems it has to do with cold weather.... cause when it is above 0 its seems to be fine , but under zero it seems to have a problem everytime i start it up. Only way around it is to turn off stat again and barely push gas until it hits second gear then i can give her like i normally do.
Hatch Nation # 111
