Two parking positions on the front wipers? - Page 2 - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 01-14-2013, 11:05 PM   #11
gondorian
gondorian's Avatar
Fan#: 105695
What I Drive: 2002 wgn (Selling) 2004 2.3 wgn 5sp
Points 1,500, Level 21
Points: 1,500, Level: 21 Points: 1,500, Level: 21 Points: 1,500, Level: 21
Level Up 50% Completed
FF Reputation: 7 gondorian Good Standing Member
Could you post a picture of what your problem is? I'm thinking of pulling my hood off pretty soon and painting it so I wouldn't mind tearing into the wipers a little but I would just need to know what to look for.
gondorian is offline
Old 01-15-2013, 02:32 AM   #12
exsodius
Fan#: 14827
What I Drive: 2002 Silver 1.6 Wagon
Points 7,116, Level 55
Points: 7,116, Level: 55 Points: 7,116, Level: 55 Points: 7,116, Level: 55
Level Up 83% Completed
Level up: 83% Level up: 83% Level up: 83%
FF Reputation: 1 exsodius Good Standing Member
Hi Gondorian!
Look at the forth picture in this link:
http://www.justanswer.com/ford/3ws68...-work-slo.html
That crank arm on the motor spindle should have been marked when i changed the motor, but my motor was destroyed so i lost my reference to the park position.
Thank you for offering your help! But i don't want you to disassemble anything for my sake. Because you could destroy the clips in the cowl. So the only reason you ever should open this up is when you have to repair something or change the pollen filter. But thanks anyway. In this forum it looks like i am the first to change the wiper motor since nobody else know this crank arm position.
Ford Focus 1.6 Wagon
exsodius is offline
Old 01-15-2013, 08:50 AM   #13
gondorian
gondorian's Avatar
Fan#: 105695
My cowl clips are already broken and I've been trying to figure out a way to fix them. It's kind of on the back-burner but I need to do it sometime.
Old 01-15-2013, 07:02 PM   #14
exsodius
Fan#: 14827
Ok. Then maybe you can help after all. Regarding the cowl clips. When my clips got destroyed i used superglue on the black pieces in the cowl an glued it back together. If this black plastic is damaged on yours and you miss the pieces they probaly are laying under the cowl. And the white clips that broke off the round piece on top, i bought new ones. They are cheap.
Just let me know when/ if you are doing this and i can describe how to look for this crank arm.
exsodius is offline
Old 01-15-2013, 08:09 PM   #15
gondorian
gondorian's Avatar
Fan#: 105695
Ok, probably this weekend. (It is a long weekend in the U.S.A.)
Old 01-15-2013, 08:30 PM   #16
exsodius
Fan#: 14827
Ok, i will think about the easiest way to describe this. Do you have a camera?
Happy long weekend!
exsodius is offline
Old 01-17-2013, 07:27 PM   #17
exsodius
Fan#: 14827
Ok here is a description. Assuming your wiper arms and cowls is disassembled.
1. Turn on ignition and pull the wiper handle down one time (one swipe) and let the motor run one cycle to stop at the park position. Turn off ignition.
2. Loosen the 3 screws that is holding the whole wiper assembly. Turn the assembly around so you can see the motor crank arm. You dont have to take it out of the car just turn it around.
3. If you have a camera take a picture of the position of the crank arm. If you don't have a camera just try to describe for me how the arm is positioned.
If you start doing this and have questions i will help you underway.
exsodius is offline
