SVT is idling better with no MAF hooked up??? - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-15-2012, 07:33 PM   #1
sweetnlo
Fan#: 105730
What I Drive: 2003 Svt Swap
FF Reputation: 1 sweetnlo Good Standing Member
I just completed an automatic to SVT swap and I continue to run into problems. My latest issue is my car doesnt idle correctly with my MAF Sensor plugged in. It runs like crap, very delayed throttle response, and eventually dies when i stop giving it gas. I forgot to say the only 2 things i had to use off my other setup (reg. zx3) was the fuel pump and the MAF sensor. The MAF sensor was missing off the svt when i bought it and Advance Auto Parts told me the part #'s were the same for the SVT MAF and the ZX3 MAF. So I used my MAF Sensor. The Fuel pump in the SVT was bad so i put mine in just to get it to start. I just replaced it with a new SVT fuel pump.
Back to my car. So when i unplug the maf sensor my car idles fine but terrible gas mileage. I guess my question is, is the svt maf different from the regular zx3 maf? could my issue be any other sensors? My check engine light is on and one of the codes was p0133 which has something to do with the IAT has High input but im not really sure what that means either.
sweetnlo is offline
Old 12-16-2012, 11:02 PM   #2
sweetnlo
Fan#: 105730
can anyone tell me if the svt maf sensor is different from the maf sensor in regular zx3 auto
sweetnlo is offline
Old 12-17-2012, 12:53 PM   #3
Stover
Fan#: 105238
What I Drive: 00 silver zx3
FF Reputation: 1 Stover Good Standing Member
yes the maf is differenct from svt to zx3, the car will nto run on a svt maf unless its tuned for it
Stover is offline
Old 12-17-2012, 01:08 PM   #4
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
What I Drive: 04 Red/Black ZX5, 00 infared ZTS
Points 2,383, Level 29
Points: 2,383, Level: 29 Points: 2,383, Level: 29 Points: 2,383, Level: 29
Level Up 56% Completed
FF Reputation: 12 Mike_Mac Great Standing Member
Buy-Sell-Trade Rating: (8)
i thought only the MAF TUBE was different, its a larger size i think. The sensor itself i believe is the same.
Mike_Mac is offline
Old 12-17-2012, 01:25 PM   #5
Stover
Fan#: 105238
Ahh u may be correct mike, I guess I assumed he meant he had the whole assembly (maf and tube)
Stover is offline
Old 12-17-2012, 01:29 PM   #6
Mike_Mac
Mike_Mac's Avatar
Fan#: 61110
thats my guess too, either way a MAF tube is probably only like 40-50 at a dealer (i would hope) and if he didn't use the SVT tube i would start there.
Mike_Mac is offline
Old 12-17-2012, 10:17 PM   #7
sweetnlo
Fan#: 105730
i am using the svt tube with the maf sensor outta my reg. zetec zx3, and when i plug the sensor in, my car idles terribly and eventually stalls out. However when i unplug it, it seems to idle fine but im getting terrible gas mileage with the air/fuel not being monitored. Ive gone about 50 miles and have used half a tank.
sweetnlo is offline
Old 12-17-2012, 10:25 PM   #8
sleepyboy
FF's Night Security
sleepyboy's Avatar
Fan#: 15335
Points 138,543, Level 100
Points: 138,543, Level: 100 Points: 138,543, Level: 100 Points: 138,543, Level: 100
Level Up 0% Completed
Forum Activity 61%
Activity: 61% Activity: 61% Activity: 61%
Buy-Sell-Trade Rating: (11)
The SVT MAF and housing is 69mm and tuned for the injectors on the SVT which are 24lbs or 36lbs I forget which and the MAF for the normal Zetec is 54mm or 56mm if I remember right and tuned for 19lb injectors. Get a SVT MAF and tube and it'll probably run fine. I'm not sure if you can just swap out tubes as far as I know.
Moderator for
Technical Chat
Zetec Performance Chat
Southern Fanatics Chat
sleepyboy is online now
Old 12-18-2012, 01:12 PM   #9
84572
Fan#: 84572
What I Drive: focus
FF Reputation: 1 84572 Good Standing Member
The reason it runs better when you unplug the maf is the computer takes over rather than recieving actual/current data from tha maf sensor(limp mode). The computer is doing the best it can with the programmed information it has. Sounds to me that you maf meter/sensor is your problem. With that being said, will the ZX3 computer/ECM support the SVT electronics without being tuned? I'm sure there are people on here much more knowledgeable than me who can answer that.
84572 is offline
Old 12-18-2012, 03:07 PM   #10
1turbofocus
FF Affiliate
1turbofocus's Avatar
Fan#: 1123
Points 51,897, Level 100
Points: 51,897, Level: 100 Points: 51,897, Level: 100 Points: 51,897, Level: 100
Forum Activity 30%
Buy-Sell-Trade Rating: (28)
Your going to have many issues , give me a call and I will try to help
Customer Support
AIM: hpdyno
Email: hpdyno@aol.com
Phone: 704-249-3745
Site: focus-power.com
Elder 1turbofocus
1turbofocus is online now
