HELP!!!!! Turn over, but engine wont start!!!!! - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2012, 05:16 PM   #1
jlawlax1344
Fan#: 99464
What I Drive: 2003-CD Silver-SPI-5spd
Points 197, Level 3
Points: 197, Level: 3 Points: 197, Level: 3 Points: 197, Level: 3
Level Up 94% Completed
FF Reputation: 1 jlawlax1344 Good Standing Member
Exclamation HELP!!!!! Turn over, but engine wont start!!!!!
I was driving my focus earlier today and it would start to sputter on me a lot, and tried to cut out several times. It never did but once i parked it the check engine light came on and i turned the car off. Later when i went to head to work, i tried to start my car and it would turn over, and try to start, but will not fully start.
I have recently replaced the spark plugs, wires, distributer cap, battery, and starter.
I also recently had the alternator checked and it was working perfectly fine. When i turn it to AUX all my lights and accessories come on and work, and the car will turn over, but wont start.
I think this could be a bad fuel pump or pump relay, but I am pretty sure it is fuel system related.
ANY help or input would be greatly appreciated!
2 12" rockford fosgate subs,1500w Hifonics amp, throttle spacer, performance chip, FSWerks 2.5" race exhaust, custom CAI w/Spectre 10.5x6 filter Blue leds all around pulsating in the trunk, smoked taillights and turn signals
jlawlax1344 is offline
Old 12-15-2012, 05:22 AM   #2
poppop
poppop's Avatar
Fan#: 59702
What I Drive: 2001,Red,LX
Points 251, Level 5
Points: 251, Level: 5 Points: 251, Level: 5 Points: 251, Level: 5
Level Up 2% Completed
Forum Activity 2%
FF Reputation: 2 poppop Good Standing Member
Pop the fuel line off, put it in a bottle, turn the ignition and see what you get.
poppop is offline
Old 12-15-2012, 07:17 AM   #3
TheGlassMaker
REVOLT.BUILD.RISE
TheGlassMaker's Avatar
Fan#: 69510
Points 35,435, Level 100
Points: 35,435, Level: 100 Points: 35,435, Level: 100 Points: 35,435, Level: 100
Level Up 0% Completed
Forum Activity 5%
Is this what it sounds like when it sputters?
Click me
Cause what you are describing to me is the exact issue mine was doing months before the engine dropped a valve seat. It was giving me a warning and I kept putting band aids on it not knowing it. I replaced the Crank position sensor, pressure control valve, Idle air control valve, and the ignition coil. All seemed to make it better and it would be fine for several weeks and then it would start sputtering again, and stop wanting to start again. Then it would be fine again with me doing nothing to it, then it would go back to doing the symptoms again. Finally one day my wife took me to work, car was fine. She then drove to school, she decided to pull into a gas station to get a pop and the car shut off on her as she was pulling up to a pump. It had never just randomly shut off, she tried to start it but all it would do is crank and crank and crank. She thought it was just going through it's not wanting to start faze again so she let it sit for a lil' bit. Then she tried again, it cranked a few time then finally it started up. but she said it sounded like the engine was grinding and screaming, it shut off again after about 30 seconds of running. It has never ran again.
Just a warning, Good Luck.
TheGlassMaker is online now
