LCQ-1 install - Ford Focus Forum, Ford Focus ST Forum, Ford Focus RS Forum
Old 12-14-2012, 04:48 PM   #1
Besbro
Besbro's Avatar
Fan#: 102785
What I Drive: 2012, black SE Sport
FF Reputation: 1 Besbro Good Standing Member
LCQ-1 install
Hello, I will be replacing my LOC for a LCQ-1 in a couple days. I am running a front stage and one 10 inch sub off separate amps. I had the stock 6 speaker system initially. Would I be better to run the front speaker wires into channel 1 and the rear speaker wires into channel 2 (for the sub) on the LCQ-1 or is it better just to run the front speaker wires into channel 2 and leave the rear speaker wires disconnected? I know the LCQ-1 gets its sub signal off the channel 2 signal. I read that the rear speaker signal is not complete, that anything lower than 45 hz is cut off, but the front signal is complete. Is this true?
Thanks!
Besbro is offline
Old 12-16-2012, 10:00 AM   #2
Besbro
Besbro's Avatar
Fan#: 102785
Bump.
Besbro is offline
Old 12-17-2012, 09:06 AM   #3
ArcticGabe
Fan#: 86046
What I Drive: 2013 SE Hatch MTX
FF Reputation: 1 ArcticGabe Good Standing Member
I'm thinking of doing the same thing to mine. Where are you mounting the LCQ-1? I'd like to mount it up front, close to the head unit so I do not have to run speaker wires up and down the car.
I have not heard that the rears are rolled off below 45Hz, but I see nothing wrong with using channel 2 for the fronts. You may want to test to make sure the auto-sense turn on works from channel 2 inputs, else you may need to run a separate turn on trigger. I believe the factory trigger is the Yellow-Violet from the radio unit (at least it is on the Sony systems).
ArcticGabe is offline
Old 12-17-2012, 09:35 AM   #4
Besbro
Besbro's Avatar
Fan#: 102785
I will be mounting my LCQ-1 in the hatch as I have already run the wires (I am using a basic LOC now). I would rather use both channels on the LCQ-1 so I can maintain the fade control on the hu. I just would like to confirm no bass roll off on the rears.
Thanks!
Besbro is offline
Old 02-19-2013, 11:00 PM   #5
virtualbeas
Fan#: 109214
What I Drive: 2013 Ruby Red Focus Titanium
FF Reputation: 2 virtualbeas Good Standing Member
How did your LCQ install go? Any bass roll-off?
virtualbeas is offline
Old 02-20-2013, 10:37 AM   #6
Besbro
Besbro's Avatar
Fan#: 102785
The switch from the basic LOC to the LCQ-1 was huge. Sound quality is much improved. After setting the accuBASS on the LCQ-1 I have no bass roll off. I did feed the LCQ-1 front channel off of my factory front speaker wires. I am very happy with it.
Besbro is offline
Old 02-21-2013, 02:11 PM   #7
crice8
crice8's Avatar
Fan#: 84830
What I Drive: 2010 Sterling Gray Focus SE Sedan
Points 8,540, Level 62
Points: 8,540, Level: 62 Points: 8,540, Level: 62 Points: 8,540, Level: 62
Level Up 30% Completed
FF Reputation: 9 crice8 Good Standing Member
Buy-Sell-Trade Rating: (13)
I recently did this but with an LC6i instead. Sound improvement was amazzzzinggggg and the clarity is much better along with better bass output because my signal to my amp is now much higher so the amp doesnt have to work as hard to amplify the weak hu signal. As for wiring I run my sub rcas from the rear speaker inputs. I mounted mine under the rear seat cushion.
Galatians 6:14
crice8 is offline
Old 05-04-2014, 04:26 PM   #8
Xenon
Fan#: 150250
What I Drive: Red 2012 SEL
FF Reputation: 1 Xenon Good Standing Member
Where was the wire bundle you spliced into to get each speaker wire out to the lcq-1?!
Xenon is offline
Old 05-12-2014, 11:48 AM   #9
Besbro
Besbro's Avatar
Fan#: 102785
I spliced into the harness on the passenger side center kind of under the gear shift. The side panel pops off and the harness is right there.
Besbro is offline
Old 05-12-2014, 04:29 PM   #10
Xenon
Fan#: 150250
Would you mind posting or sending me a picture of your lcq eq settings? Looking for a good starting point.
Xenon is offline
