#1 | ||||
Dreaded Can't fill gas tank problem
Okay, I have a 2005 zx5. Owned it since new.
All of the sudden it takes 30 minutes to fill up because of fuel splash back on the pump nozzle turning pump off. I have read many posts on the problem, but really don't see where anyone has found a solution. 1) Spider nests in vent tube. - I have removed both the vent tube. No clogs 2) Some type of clog in fill tube. - I have pulled the fill tube. First I tried running a siphon hose through. Hose would not go through, so I thought this might be the problem. After pulling the tube have declared it clear. 3) Pulled gas tank to check tank venting. - Tube is clear to the charcoal/EVAP canister. - Exit tube from EVAP Canister clear to Fuel Vent, up to Fuel Fill. Apears the The Charcoal Canister/EVAP is the problem. So, here's where I need help. The Charcoal Canister/EVAP is wedged above and between the rear end and the bottom of the vehicle body. How is this thing suppose to come out? After looking at it for a few nights, I am thinking I will cut a huge hole in the floor panel by the spare tire and pull it out the top. Otherwise I think I need to drop the rear end - at least one side. Anyone ever replace the Charcoal Canister/EVAP that can help me out here. Anyone have the Ford Service manual that can shoot me the directions for Removal/replacement? Thanks, any advice appreciated. |
Remove Advertisements |
Fan#: 1
#2 | ||||
Shrink All The Cars!
Is this what you are looking for: http://www.focusfanatics.com/forum/showthread.php?t=276213 I hope this helps!
Hatch Nation #8
September 2012 Ride of the Month | Ford of Europe | Hofele | Rieger | Hella | OEM+ | |
#3 | ||||
That is a sweet write-up for the Fuel sending unit. Thanks.
I already have the fuel tank out though. Since I may be cutting holes, maybe I should do that one too, in addition.... I'm thinking of doing the same thing for the EVAP/Charcoal Canister. Cut the floor panel. I was hoping not to do that if there was an easy way to drop the rear end or get the damn canister out. |
#4 | ||||
Sorry it wasn't what you were looking for. But since this works great for the fuel filter, it might just be a good idea to cut a hole where you need it too
Hatch Nation #8
#5 | ||||
Okay, after searching for several days I found that the rear end is called a rear sub frame. There are 5 bolts on each side that hold the rear sub frame in. I basically put the whole car on jack stands with about 30 inches of clearance. With wheels removed put a hydraulic jack under each rear spring. loosened the 5 bolts on each side and lowered the rear sub frame. I was then able to remove the charcoal canister assembly. As previously diagnosed, the charcoal canister was plugged up.
Recommendation: The EVAP lines have special clips on them and I have not been able to find replacement clips. So use great care in removing the lines and do not break the clips. After reinstalling everything, I can now pump gas into the vehicle with no issues. Problem solved. Hope this helps others with a similar problem. |
| Thread Tools | |
| Display Modes | |
